Page 3 of 5
Re: New to me 1995. MZ Country 500
Posted:
Sun Dec 27, 2020 3:56 pm
by DAVID THOMPSON
removing the cover is OK
it will not save on the mess
this bikes oil change seems the be a mess
its the biggest mess of any bike i have ever owned
Dave
Posted:
Mon Dec 28, 2020 4:46 am
by Puffs
Then you'll be doing similar as I with my SP. Place a suitable bowl...
Rotax is Austrian so I'd guess that cover is made there too. But indeed maybe aftermarket - or old stock? Maybe Can-Am also used Rotax?
Quick look says yes, they still do.
Posted:
Mon Dec 28, 2020 6:16 am
by breakwellmz
What engine is that? Looks like half of a water-cooled twin in the image i can see.
Posted:
Tue Dec 29, 2020 6:50 am
by Puffs
Right-mouse click --> view image; in that pic it's both the 900 triple & 600 twin from their Ryker
https://can-am.brp.com/on-road/us/en/models/ryker.htmlIn their Spyder they put a 115HP 1330cc Rotax. Also in 2021.
More:
https://www.rotax.com/en/products/rotax ... rains.html
Posted:
Tue Dec 29, 2020 12:26 pm
by Little General
Well that sure ain’t the little 500 single in my bike. Yes Can Am uses the Rotax engines and most of the parts are the same except the bing carburetor and exhaust systems.
Posted:
Tue Dec 29, 2020 1:43 pm
by DAVID THOMPSON
give me the 600 ace with cvt and a wood racing flat track frame
and i will build a weapon that will scare people
atkusa 605 esds mid 1990's comes to mind but a bit on the tall side for short people
and if you find a good used one you need a DEEP pocket book
Posted:
Tue Dec 29, 2020 2:20 pm
by breakwellmz
CVT is interesting -
They do look good, not come across a road legal one before.
Posted:
Wed Dec 30, 2020 6:49 am
by Puffs
I don't know the details of their CVT, but it is likely to cost power. I don't mind shifting.
That's a nice looking flat track bike. It isn't, but it reminds me of the CCMs from a while back; didn't they also use that Rotax engine?
The ATK David mentioned:
Gorgeous bike IMO. Details from
https://www.motorcyclespecs.co.za/model ... 5%2096.htm
Posted:
Wed Dec 30, 2020 7:44 am
by breakwellmz
Probably the largest user was Harley D and Armstrong for their military bikes.
Posted:
Fri Jan 01, 2021 4:49 pm
by Little General
I have new tires coming Monday and I understand there is a certain way to remove the rear wheel. I get that I remove the left hand axle bolt which is separate from the right side that holds the sprocket side. Exactly what happens next. Remove the spacer and does the brake hub come off with the wheel ? I understand I think the wheel comes off and the drive sprocket stays. Any help or pics would be great. Otherwise I will play it by ear.
Posted:
Fri Jan 01, 2021 7:13 pm
by DAVID THOMPSON
hold nut on right side and remove axle on left
it may be o there very tight
remove left spacer brake rod and brake hub then wheel
leaving hub on right and chain in place
the axle is a 2 piece with part of it staying mounted with chain and chain cover
axle is removed out left side
Posted:
Fri Jan 01, 2021 8:25 pm
by Little General
Thanks Dave. Since there are a few people that have asked and no pics , I will try to document the process in photos. It seems Bridgestone has a new tire , the Battleax 41 , that is the correct size and hopefully it won’t rub the rubber chain enclosure. It the outer lugs touch the chain protection, I will just trim them down a little with a side grinder. If I get that far , I am not removing the tire. Lol.
Posted:
Sat Jan 02, 2021 5:53 am
by Puffs
Posted:
Sat Jan 02, 2021 10:06 am
by DAVID THOMPSON
i have reached the point if i take any thing apart it has to be in small pieces
or i have my feet stuck on the ceiling and my face buried in the FLOOR
my get up and go is on strike
now 75 and on the down hill slide
Posted:
Sat Jan 02, 2021 2:14 pm
by Little General
Thanks Dave and Puff. I think I understand it now. Seems fairly straightforward.
