BAGHIRA TYRE PRESSURES AND SPARK PLUG INFOR
Postby baggzy » Fri Mar 17, 2017 6:24 am
Hi Guys,
can anyone tell me the recommended tyre pressures for a Baghira with 21" front and 18" rear wheels fitted. Also - what spark plug does it take?
thanks
Sam
baggzy
Re: BAGHIRA TYRE PRESSURES AND SPARK PLUG INFOR
Postby baggzy » Fri Mar 17, 2017 8:31 am
Forget about the spark plug. I have found the correct one already. Jut need tyre pressures now
baggzy
Postby edfmaniac » Fri Mar 17, 2017 8:41 pm
If you are riding on the road with road tires, use the recommended pressure printed on the tire. If you are riding mixed, or off road, pressure is going to depend on tire type, terrain and riding style.
Postby breakwellmz » Sat Mar 18, 2017 3:33 am
According to handbook-
Front-27psi
Rear-32psi (Max 36psi)
Plug- NGK DPR 8 EA 9 , DPR9 EA 9 or DPR 9 EV 9
Postby baggzy » Sat Mar 18, 2017 5:45 am
Thanks for the info mate. It is appreciated!!
baggzy
Postby baggzy » Wed Apr 26, 2017 3:54 pm
anyone out there know the spark plug gap??
baggzy
