Baghira rear disc 17”
PostPosted: Sun Sep 29, 2019 8:29 pm
by Blue
Hi All,
I’ve searched for a while in the forum and online but can’t find any info on where to get a rear brake disc. Mine is cracked and I’m in need of a new one. Anyone have any info of where to get an new OEM, used, or different model that works? Literally anything to get ridding again that doesn’t involve a whole new wheel. Or is that my only option?
Thanks.
Re: Baghira rear disc 17”
PostPosted: Mon Sep 30, 2019 11:54 pm
by Guesi
PostPosted: Tue Oct 01, 2019 6:09 pm
by WernerLE
Yamaha XTZ750
I use ECB MD6119 5mm thik,
look for the clearence of the Boltheats !!!
PostPosted: Tue Oct 01, 2019 7:48 pm
by Blue
Thanks for the info. And for bolt clearance, is there a shim I can add somewhere? It’s obvious the guy I got the bike from didn’t pay attention to this since the bolts were rubbing on the caliper and damaged both. I had to drill the bolts out.
PostPosted: Sun Oct 06, 2019 3:01 pm
by tigcraft
CCM run on same wheels. Not sure what discs they run although you'll have to check it out.
