Re: skorpion carb
PostPosted: Fri Mar 13, 2020 5:51 pm
by dellboy77
Skorpion carb help please pipe work
Looking at carb from air box side where fuel
Goes in pipe above is that just a overflow
( no pump fitted )cheers del
Re: skorpion carb
PostPosted: Sat Mar 14, 2020 1:18 pm
by dellboy77
Pull my carb off cant fine any problem
But there must be ?
The bike starts first time every time tick over prefect
When going runs well till
I start to slow down fill like it starting to run out or petrol never
Cuts out open throttle again pick up prefect ?
Re: skorpion carb
PostPosted: Sun Mar 15, 2020 5:36 am
by Puffs
It's a riddle, yes?
Maybe the level in your float bowl drops, combined with a rich high & a relatively lean low & mid-speed jetting. Check the long-term flow from your fuel pipe into the bowl. Tank vent?
Re: skorpion carb
PostPosted: Wed May 27, 2020 11:57 am
by dellboy77
when out today first ride since lockdown put another carb on same problem need to know where pipes go on carb after pump remove please thank again tank vent clear
Re: skorpion carb
PostPosted: Wed May 27, 2020 5:44 pm
by breakwellmz
The well hidden filter under the float valve maybe?
Re: skorpion carb
PostPosted: Wed May 27, 2020 5:45 pm
by breakwellmz
viewtopic.php?f=3&t=10435
