Rear brake Caliper rebuild ?
PostPosted: Mon Nov 09, 2020 7:11 am
by buell1965
Hey guys rear brake caliper on the skorpion has been replaced with another used part and is not showing much promise . My question is , is there a rebuild kit for that caliper or just find a Brembo p32f .thank you in advance
Re: Rear brake Caliper rebuild ?
PostPosted: Mon Nov 09, 2020 9:15 am
by breakwellmz
Pistons sticking?
Unless they are really bad and you have the time and patience to do it strip the thing down yourself, you may be surprised at what can be achieved!
PostPosted: Mon Nov 09, 2020 10:50 am
by buell1965
Roger that , I was afraid if I separate the caliper body I would not be able to find a rebuild kit , as is one caliper seeps fluid at the seam in the middle and the replacement from Steve's cycle here in georgia is not wanting to pump up . I agree there is nothing to lose by a disassemble and good advise . Cheers
PostPosted: Mon Nov 09, 2020 11:31 am
by breakwellmz
As i remember there is only an O ring in the middle and they`re available all sorts of places, give it a go!
PostPosted: Mon Nov 09, 2020 1:25 pm
by buell1965
breakwellmz wrote:As i remember there is only an O ring in the middle and they`re available all sorts of places, give it a go!
heck yea , and that's my plan thanks for the insight and will update as resolution gets nearer .
PostPosted: Mon Nov 09, 2020 4:00 pm
by breakwellmz
Penetrating fluid and heat are your new best friends, but not together! :)
PostPosted: Mon Nov 09, 2020 10:06 pm
by DAVID THOMPSON
some of the systems do not bleed well forcing the fluid down
force it up from the pucks to the upper reservoir with a fill bottle and a mighty vac type pump
the air goes up faster than the oil can take it down
when you try it by the car method
