Black Panther --> Enduro: Wheel swap 21"/18" ?
PostPosted: Tue Sep 14, 2021 11:14 am
by Τοβίας Χάος
Hey everyone! :D
I just, rather unexpectedly, came into possession of a 2001 Black Panther. Hasn't been moved for a while but seems to be in good condition. I might need to get back to this forum once I have it here and know more about what needs to be done.
Anyway, I am currently using my RD07 Africa Twin for trail riding (and I love it); I would love to get the Baghira out on the trails, too. It's a very very capable bike, great engine, awesome components. Maybe a bit heavy for some, but still 100kg lighter than the AT, so a fly-weight for me! ;)
The bike comes with Supermoto wheels and I would need to get MX/Enduro wheels in 21" and 18" somehow. I know there have been threads and I went through them but most of them are really old and I would love to know if there have been any other solutions by now?
Who has experience with this? Which wheels can be fit? How much work is it? What needs to be changed? What price range can be expected? Things like that. :)
If anyone has offroad-experience with the SuMo wheels, I'd also be interested in hearing about that! 8)
Thanks in advance and greetings from Croatia.
Re: New Black Panther in the stable
PostPosted: Tue Sep 14, 2021 1:26 pm
by DAVID THOMPSON
use the wheels just get some tires that fit the dirt in your area
where i live all the bikes run street tires
we go mudding in a 4 wheel drive
PostPosted: Tue Sep 14, 2021 3:37 pm
by Τοβίας Χάος
DAVID THOMPSON wrote:use the wheels just get some tires that fit the dirt in your area
Haha, thanks! :wink: :-D
There are no real knobblies available in that size - and I also wouldn't wanna go trail riding with a 160 in the back and a 17" in the front. :wink:
Well, I have street tires on my street bike ('96 VFR 750). :mrgreen: The trail bike needs trail tires, though.
Naaah, 4 wheels are two too much.
So - I still hope to get some feedback/advice... :)
Re: New Black Panther in the stable - Enduro wheel swap 21"/
PostPosted: Wed Sep 15, 2021 4:57 am
by Puffs
PostPosted: Wed Sep 15, 2021 11:00 am
by Τοβίας Χάος
Puffs wrote:Hi Toby,
Looking at https://www.motorcyclespecs.co.za/model ... anther.htm, indeed an 21" F should fit, but I'd still make sure: take out the springs & see how far up that wheel comes.
Hey! :) I went through the complete spare parts list - both models are 100% identical except for the wheels/brakes. Which means, forks and swingarm are the same, so the wheels will fit without doubt.
Puffs wrote:I wouldn't know which alternative wheels would fit, but if you're determined you can always re-lace other rims onto the original hubs. In principle a 17" at the R shouldn't be too much of a problem (many dual purpose bikes have that, and maybe you can fit something smaller than 160/60-17), but if you combine it with a 21" at the F the geometry might become a bit lazy. 17"R/19"F is possible too, and more direct & better fitting the original steering geometry, and in that you can find ample tyres.
I'd like to go for 90/90-21 and 120 or 130/80-18 - just works best. I'm sure someone here has put on wheels from another model. I guess I could try to do research on which other bikes use the same forks... Still hoping someone will have some advice! :)
Puffs wrote:At 164kg dry it'll remain a dual purpose bike, but with that XT engine & Paioli/WP suspension (280mm on either side) it should be great for trail riding. Good luck!
Exactly! :mrgreen: :smt004
The components are fantastic, it would be such a fun trail bike! Sure, it's not mega light but 160 kg are fine. My Twin weights in at about 230 kg....
PostPosted: Thu Sep 16, 2021 3:42 am
by Puffs
Which 'works best' will remain a subjective choice, but many of the big trails bikes have 17" at the rear. In the past I extensively used a DR600 for trail riding; case in point. But I admit that 18"R/21"F is a conventional choice for enduro bikes, while even 19"R/21"F has gained popularity in both MX & enduro. Yet neither MX nor enduro uses trails bikes.
And here one other issue plays a role: if you change the OD of the wheels, you also change the steering geometry. With a bigger F wheel, the forks will become more horizontally oriented. I do not know how much development work MZ put into steering geometry, or if the steering head angle of the SuperMotard version is different from other Skorpions, but offhand it might be sensible to not diverge too much from the original design. Of course it's your choice.
How much weight is acceptable depends on your own physique & technique, but most of all on the conditions you ride in. On the big open plains in Africa a bit of weight hurts a lot less than on tight rocky forest climbs.
PostPosted: Thu Sep 16, 2021 8:39 am
by Τοβίας Χάος
Puffs wrote:Which 'works best' will remain a subjective choice, but many of the big trails bikes have 17" at the rear. In the past I extensively used a DR600 for trail riding; case in point. But I admit that 18"R/21"F is a conventional choice for enduro bikes, while even 19"R/21"F has gained popularity in both MX & enduro. Yet neither MX nor enduro uses trails bikes.
You're right, of course - I should have added "for me". :wink: Yeah, it's true, there are different set-ups but I just feel that 21"/18" works really well for what I do. Anyway, we'll see what I can get.
Puffs wrote:And here one other issue plays a role: if you change the OD of the wheels, you also change the steering geometry. With a bigger F wheel, the forks will become more horizontally oriented. I do not know how much development work MZ put into steering geometry, or if the steering head angle of the SuperMotard version is different from other Skorpions, but offhand it might be sensible to not diverge too much from the original design. Of course it's your choice.
Interesting (and important) thoughts. Now, I don't know how much thought MZ gave the steering geometry in general :-D but what I do know is the following:
1. The Baghira Enduro is used and loved by many as a dirt/trail bike/Enduro and it seems to perform really well.
2. The Enduro and SM models are virtually identical in all regards (geometry, components) - except the wheels (and brakes, ofc).
3. The Enduro model is rocking stock 21"/18" wheels.
4 Hence, swapping wheels (and brakes etc) would virtually make the Black Panther an Enduro. 8)
Puffs wrote:How much weight is acceptable depends on your own physique & technique, but most of all on the conditions you ride in. On the big open plains in Africa a bit of weight hurts a lot less than on tight rocky forest climbs.
Yeah, the latter is what I mainly do. Rocky mountain paths, trails through the woods, gravel, some sand, some hard-packed dirt, some mud - European standard stuff. ;)
I wouldn't say I'm strong, and I am very lightweight, BUT I'm in good shape and I know how to pick up a bike. So that works. ;)
PostPosted: Fri Sep 17, 2021 3:19 am
by Puffs
I have no advice on complete wheels, I'd just buy rims & spokes then.
PostPosted: Fri Sep 17, 2021 3:42 am
by Τοβίας Χάος
Puffs wrote:I have no advice on complete wheels, I'd just buy rims & spokes then.
Thanks anyway! :smt023
That would be a solution, if an expensive one. Get rims and spokes, and use the rest from the SM wheels. I guess the SM brakes would be fine for trail riding as well. They are a bit bigger than the Enduro ones but that shouldn't be an issue (?)
Jeez, if rims weren't that expensive....
