Re: Valve Adjustment
Posted: Tue May 09, 2006 1:22 am
yes! but it's not the reason it started backfiring - more - after the dealer adjusted the carb. "much much worse" let me spell it out to you - you are not going to sort out the wrongly adjusted carb by adjusting valve clearances - if they need it. and if he can't sort out the carb adjustment, then you going to trust him to check valve clearances. !?!!
