radiograf wrote:Number plates in the UK have to be a specific size and style by law, and are required to have the manufacturers name on them. As for fitting led rear nice led lights, you may have to fit a blocking diode in the side light circuit as the front light may flash on when you apply the brake. This is because most led rear lights get brighter as extra current is supplied via the brake light circuit, in an ordinary bulb its handled via a second filement.
radiograf wrote:If this doesn't work, it might be worth trying an Easy Clutch. They are used by off road riders to lighten the clutch pull, and fit between your own cable and the boss. Available on US ebay for about $30, or UK ebay at £15ish. Its one of the things that has been suggested for use by the National Association for Bikers with a Disability http://www.nabd.org.uk for riders with reduced power in their hands.
Can't say I've used it my self,but examples I've seen seem well made.
