If you need to pull the
flywheel, do yourself a favor and build one of the 1/2" plate pullers that are posted in previous threads or use KEDO's
flywheel puller in combination with a good air impact. Harbor Freight's $50 electric 1/2" impact will work too.
I thought something snapped when it finally popped off.
Don't forget the thread protector that KEDO sells as well. You'll destroy your crank if you don't use something like it. As far as I know, the only US dist. is The Vintage Spoke. Their site is down right now but you can reach Tammy at
tvs.tammy@gmail.com. Have your catalog numbers ready.
http://www.kedo.com/products/30270.html KEDO also sells the Mikuni's that are already jetted for our engine.
- 001366.gif (31.79 KiB) Viewed 1807 times
