gear lever availibility
Re: gear lever availibility
Postby Guido » Fri Jun 20, 2014 6:03 am
Brand new one on Ebay.DE this morning
Item No. 121367779701
Regards Allan
Guido
Postby den » Fri Jun 20, 2014 7:28 am
Guido wrote:Brand new one on Ebay.DE this morning
Regards Allan
HOW MUCH!!!!! :oops:
den
Postby Guido » Fri Jun 20, 2014 9:10 am
69,00 euro (55.00) GBP since they are no longer available seems quite fair .
Allan
Guido
Postby handsomejackuk » Fri Jun 20, 2014 2:10 pm
not bothering anymore, mine is sorted so just putting up with what i got, its better than the old setup anyway, now i am more used to it...
handsomejackuk
Postby breakwellmz » Fri Jun 20, 2014 7:12 pm
Good :D
But you could at least show a photo of what you got! :roll:
Postby den » Sat Jun 21, 2014 4:07 am
breakwellmz wrote:Good :D
yeh come on , lets see this ,,
den
Postby handsomejackuk » Thu Jun 26, 2014 6:00 am
i get some pics sorted later.
handsomejackuk
Postby breakwellmz » Tue Jul 29, 2014 3:37 pm
Is it that ugly you dare not share it?
Postby DAVID THOMPSON » Tue Jul 29, 2014 8:42 pm
if his camera is like mine ...it never works when i need it
have to work on it or find the memory card and steal the batteries the wife grabbed and put in her adding machine
need to figure out how the unit works in this new dell laptop and use it
but may break it if i take a picture of my self. :smt040
dave :-D
Postby rodge70 » Mon Aug 11, 2014 8:54 am
here is my lever that snapped off on friday on way home from work,just pulled away from lights,went to change and got neutral and that was it :shock:
thought that was weird till i noticed there was no lever :roll: looked back and saw it in the road,so managed to get the bike in 1st with the remains of the lever
and that was a fun ride home too,over temp warning lights flashing,lots of coasting,high revs etc etc.
today had a look around the shed and in the box of maico/suzukix7 project bits found a lever,may even be from an x7 not sure,seems to fit ok and had to warm it a bit and put i slight bend in it to clear a casing screw,will test drive later.
not rung grahams yet but think someone on here said they are no longer available.
rodge70
Postby handsomejackuk » Mon Aug 11, 2014 4:32 pm
looks loads better than my setup Rodge... i got to say...but mine is still too far forward...
handsomejackuk
Postby breakwellmz » Tue Aug 12, 2014 12:33 pm
According to a 2011 post on here an XT550 one fits-
viewtopic.php?f=3&t=5155&p=28750&hilit=gear+spline#p28750
And the cheapest place to buy one on EBAY is Germany-
http://www.ebay.co.uk/itm/Schalthebel-Y ... 53ec24725e
You tried yours out yet Rog?
Postby rodge70 » Tue Aug 12, 2014 2:43 pm
hi martin,yep all works ticketyboo,could doing with being 1" shorter, that would bring it roughly the same as the original one,also needs to come out a bit if i'm honest but other than that works fine,may even not bother sourcing a new one,though will need to sort something out for the maico/x7 project should it see the light of day :roll: :roll: :roll:
rodge70
Postby duncmac » Tue Aug 12, 2014 3:30 pm
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby breakwellmz » Tue Aug 12, 2014 4:39 pm
rodge70 wrote:hi martin,yep all works ticketyboo,could doing with being 1" shorter, that would bring it roughly the same as the original one,also needs to come out a bit if i'm honest but other than that works fine,may even not bother sourcing a new one,though will need to sort something out for the maico/x7 project should it see the light of day :roll: :roll: :roll:
That`s nice! :)
Do you notice any benefit in your new one piece lever to warrant changing from the standard set up if it wasn`t broken?
Anyone know the German for hideous? :lol:
