Skorpion Selenoid
PostPosted: Fri Jun 13, 2014 4:27 pm
by jaywillie2912
My Skorpion has a selenoid - Hitachi MS5D-361. Does anyone know where I might find one.
Re: Skorpion Selenoid
PostPosted: Fri Jun 13, 2014 5:56 pm
by edfmaniac
You don't need an exact replacement. Any 12v solenoid that will handle as many or more amps than the OEM unit and will slide into the rubber mount will work. Google your part number and you will find many solutions. Sounds like this Yamaha part will work but you may want to confirm before ordering. 4KD-81-940-00
PostPosted: Fri Jun 13, 2014 6:01 pm
by edfmaniac
Graham's can probably help you with some new old stock if you can't confirm the Yamaha part, or something that is guaranteed to fit at least. http://www.grahamsmotorcycles.com/2010% ... n_Menu.htm
PostPosted: Fri Jun 13, 2014 7:48 pm
by DAVID THOMPSON
Most any yamaha atv has same unit
Dave
