RT125 Strut adjustment.
PostPosted: Sun Sep 09, 2012 10:40 am
by djsbriscoe
Any suggestions on getting the large 32mm nut (1) to loosen on the rear strut of my RT125?
RT125 Strut
I'm not sure if it's a right or left handed thread. I have to try to loosen the nut whilst the strut is installed otherwise I won't be able to get enough leverage on it. I have the appropriate large open ended spanner of course as well as both of the short stubby ones in the OEM "toolkit".
Any help appreciated. Thanks.
David.
Re: RT125 Strut adjustment.
PostPosted: Sun Sep 09, 2012 1:05 pm
by cat
Penetrating oil - spray oil, like WD-40 or whatever. Spray from the top of the nut. Spray every evening for a few days. You could try again after it's had 24 hours or so to penetrate. When you get it to move, stop and lubricate the thread below the nut. ...i'd put a few drops of oil - motor oil on top and let it penetrate for a few minutes as well.
It would be a normal righthand thread - unless it's a real oddity.
PostPosted: Sun Sep 09, 2012 2:47 pm
by DAVID THOMPSON
while your in there see if there is a brand name and any numbers ..on it
so we have the info if some one needs a new one
i think wilbers make one bust your pocket book wide open :-D
PostPosted: Sun Sep 09, 2012 4:05 pm
by djsbriscoe
I'm not removing/replaceing it, only adjusting it. It's probably a Bilstein anyway.
David.
PostPosted: Mon Sep 10, 2012 12:24 am
by radiograf
Try using a spring compressor to compress the spring (Doh!). This should releave the pressure on the nuts allowing them to turn.
