Baghira Exhaust
Baghira Exhaust
Postby Glidd » Tue Nov 05, 2013 5:20 am
I'm planning to replace the stock exhaust on my 2003 Baghira and hoped someone could recommend an alternative, something lighter and a little louder. I've seen road legal GPR exhausts advertised by a UK company, does anyone have any experience of them? Or does anyone in the UK have an exhaust for sale?
Dave
2003 Baghira SM
1995 ZZR1100
Redditch
UK
Glidd
Re: Baghira Exhaust
Postby den » Tue Nov 05, 2013 3:55 pm
have you considered chopping your original exhaust for the connection 2 into 1 pipe and buying a slipon,,youll have a choice of many then,,
its all about the money and what you can afford,,iv used the gpr connecting pipe and ive custom shortened a carbon end can from a 900 fireblade c1/c2
i found the honda cbr fireblade c1/c2 (old model 98/99)
and kwak zx900 c1/c2 has a perfect match for the three bolt holes on the gpr link pipe?
den
Re: Baghira Exhaust
Postby rodge70 » Tue Nov 05, 2013 4:07 pm
[/img]Image
this is my homemade off road pipe :D
you can use your standard pipe by cutting off the branch,think you end up with a 2" dia outlet,find a suitable link pipe and end can to go on it.
i also have a bsm pipe for road use,from dave silvers,which has a removable db killer
anything would be lighter :D :D
rodge70
Re: Baghira Exhaust
Postby Glidd » Sat Nov 16, 2013 6:18 am
Thanks for the suggestions guys, I'm chopping the original pipe this afternoon.
Cheers
Dave
2003 Baghira SM
1995 ZZR1100
Redditch
UK
Glidd
Re: Baghira Exhaust
Postby BigDog702 » Fri Jan 03, 2014 7:32 pm
Hey Guy's,
What about Carb. jetting with the open Cans ?
What were the changes you had to make ?
Stock carb., Mod stock, or Aftermarket carb. ?
BigDog702
Re: Baghira Exhaust
Postby bluerob » Wed Feb 05, 2014 4:10 pm
I work for GPR UK and can offer any help if required?
bluerob
Re: Baghira Exhaust
Postby Glidd » Thu Feb 06, 2014 5:14 pm
Hi bluerob, I bought a second hand baghira exhaust but didn't get as far as taking a saw to it. The tri oval looks a good system, would any carb mods be needed?
2003 Baghira SM
1995 ZZR1100
Redditch
UK
Glidd
Re: Baghira Exhaust
Postby den » Fri Feb 07, 2014 9:43 am
glidd ,,,the topics been covered here--- viewtopic.php?f=20&t=5982
den
Re: Baghira Exhaust
Postby bluerob » Fri Feb 07, 2014 2:28 pm
GPR exahusts are generally just plug and play items. Fit it, start it, go have fun on it...
bluerob
Re: Baghira Exhaust
Postby BigDog702 » Fri Feb 07, 2014 3:16 pm
OH, My ! :lol:
Not Quite ! Not Right !
If you plan on getting anything out of an Ex. Mod, More flow !
Your going to have to get more out of your intake, Carb. Air intake, More Air & Fuel flow !
That's where Jetting changes come in.
That's if, You want to get all your money's Worth !
BigDog702
Re: Baghira Exhaust
Postby Glidd » Sat Feb 08, 2014 1:04 pm
Well I've just ordered the GPR tri oval system from Moto Legends, now I better get reading through the posts on carb mods. Thanks bluerob, good carb post den, and BigDog702; you are so right
2003 Baghira SM
1995 ZZR1100
Redditch
UK
Glidd
Re: Baghira Exhaust
Postby den » Sun Feb 09, 2014 5:06 am
i would not even think of touching the carbs if you buying one of those exhausts unless it recommends it.
There built as a direct replacement.
If anything i would check you have the option of removing the db killer for the crazy lazy summer days out :P
if you were going to mess i would just start with the main jet first,
den
Re: Baghira Exhaust
Postby Glidd » Fri Mar 07, 2014 4:21 pm
Well things did not go to plan with the GPR exhaust as the mounting brackets did not line up, the spring hooks were too close and the silencer leaked, as this is not the first time with the Baggy exhausts they could not be sure another pipe would be good so I'm back to square 1 and waiting for the refund to clear.
2003 Baghira SM
1995 ZZR1100
Redditch
UK
Glidd
Re: Baghira Exhaust
Postby Fortflory » Sat Mar 15, 2014 7:34 am
Has anyone actually cut open a original Baghira exhaust? I got one off e-bay recently and hope to start a mod on it soon but I'd like to see or know is this is a good idea or not. :idea:
Fortflory
Re: Baghira Exhaust
Postby roloscotusa » Sat Mar 15, 2014 7:57 pm
I ordered a GPR can for my Baghira and it fitted perfectly. It was a 10 minute job to replace. I did not mess with the jets and it seems to work perfectly well.
I think that you must have a wrong Can. I also order aftermarket header pipes that cleaned up the front-end. I bought these from a company in Germany.
roloscotusa
Users browsing this forum: Google [Bot] and 22 guests
