manxie wrote:I`ll take a look at that, thanks for the info. What size jets do you recommend
edfmaniac wrote:manxie wrote:I`ll take a look at that, thanks for the info. What size jets do you recommend
Keihin 135 and 155 for the mains and a Mikuni TM28/486 #40 or #38 on the pilot
edfmaniac wrote:Probably the same treatment for the other 660 models. Do they have the fuel pump that all of the Skorpion owners are supposed to immediately take off?
I think the jetting issue was pretty common in a certain era of bikes. Lean on the bottom for emissions tests, and fat on the top so the average rider could put a lifetime of riding on the bike safely, at nearly any altitude, without having to rejet it. The jets I recommended would probably be too lean in colder, high altitude settings, but really wake the bike up here at 500ft sea level and 69.4F on average.
FYI Almost every bike ever produced is leaving horsepower on the factory floor for one reason or another. You just have to do a little research for your model then put in some work, or pay someone, to uncork it. Pulling airbox snorkles or venting the airbox, matching carb boots to intake, rejetting, grinding restrictive header welds, and aftermarket performance exhausts are all things people usually do to unleash potential hp without needing a degree in high performance tuning.
breakwellmz wrote:Hi
Thanks for that.Yes, Teikei not Keihin
Teikei jets are hard to find here but so are the Keihin 1001-806 type ones that are fitted.(I`ve only found one uk source but loads in the USA)
http://www.allensperformance.co.uk/carb ... ion-chart/
At the time a 37.5 pilot jet was the largest i could find but having looked again this morning i see i can now get a 40.(The supplier appears to show steps as being 2.5)-
https://www.ebay.co.uk/itm/EBC-Mikuni-C ... hf4COBWY4A
Compared to the Puzey where i can change a jet in a few minutes, i feel there is more emphasis on getting the right jets in the MZ first time because it`s so much more of a pain to get the carb off!
The plug has always looked lean but that could be down to the small pilot jet, the exhaust end has always looked rich.
What i would really like to achieve is a much lighter throttle action, but i think with all the mechanism involved that is unlikely.
Thanks again edfmaniac.
Cheers.
