dave47 wrote:Beats me! Maybe the bearing is seized on the shaft, try tapping the inner race. Its unlikely, I admit, but what else is there?
dave47 wrote:The entire clutch actuation mech, including the bearing normally stays in the cover when it is removed. I have taken off a few covers over the years and this has always been the case. The bearing usually slides off easy. I don't know if it is possible to remove the cover and leave the assembly on the shaft. I am not a mechanic and am unable to say how you should proceed, but good luck with it.
