FORK BRACE?!
FORK BRACE?!
Postby drj » Thu Jul 13, 2006 5:36 pm
does anyone actually make a fork brace for the baggy - or do i need to MacGuyver something together?
drj
:-D
'03 Baghira (m4 pipe/black rims)
'01 XR650r (hotcam)
'00 XR400r (pumper/header/pipe/cam)
drj
Postby drj » Tue Jul 18, 2006 1:06 am
...since no one seems to make one - it appears that i will in fact HAVE to MacGyver one together, so heres my idea...
the baggy has 45mm forks and my honda has 43mm forks...so im pretty sure i can get the XR fork brace to fit (it was larger than the forks to accomodate the bushings) - it should be 'close enough' that i may only need to mickey mouse some new skinny bushings on to make it work!!
i'll let you know how it goes...
wish me luck!!
drj
:P
'01 XR650r (hotcam)
drj
Postby drj » Wed Jul 19, 2006 11:45 pm
here it is...
http://www.xrsonly.com/data_UD/src/forkbracekit.jpg
ive got one on my XR - its fairly beefy - and ive never had a problem with it no matter how hard i beat on it!! (thats sounds kinda gross!!)
drj
:-D
'01 XR650r (hotcam)
drj
Postby phlat65 » Thu Jul 20, 2006 10:41 pm
I would be very interested in how this turns out!! have you seen the one that was made for a baggy by the guy that used to be on the motardina site?
Postby drj » Fri Jul 21, 2006 1:27 am
nope. and i havent had any luck finding something thats available AND well made...but im pretty sure this is gonna work out.
drj
'01 XR650r (hotcam)
drj
Postby veggiebikerdude » Fri Jul 21, 2006 9:27 am
the guys at Telefix in Germany tell me that if I give them all the dimensions, they can suggest one which will work. They sent a PDF template out with all the dimensions on that they'd need. I';m sure it be worth your while. http://www.telefix-products.com/
Paul
"back off, man. I'm a scientist..."
veggiebikerdude
