Backfiring!
Backfiring!
Postby F0ul_Oli » Mon Mar 21, 2005 8:30 am
We had a lovely day yesterday - it was like summer so I went for a spin with a mate.
The Baggy was great, it kept up with a TRX850 on all the smaller roads, but wasn't too good on the bigger roads but neverthelesss ..
I found it was backfiring a lot - is there a way to stop it from doing this?
It seemed to be doing it on decelleration - coming up to a corner, I would twist the throttle closed, and it would go bang a few seconds later.
Will this damage the bike and is there a way of stopping it happening?
We were thinking that it might be running a little lean, but before I start fiddling, I thought I would be better off asking the people who know!
F0ul_Oli
Lean
Postby oldboyonrgv » Mon Mar 21, 2005 9:21 am
they all do that sir !!, they are set up really lean standard, it won't do any intial damage but i wouldn't want to leave it like it.
Get a dynojet kit for a Yam660 http://www.tts-performance.com/ that will sort it.
oldboyonrgv
Postby oldboyonrgv » Mon Mar 21, 2005 9:23 am
oldboyonrgv
Postby keithcross » Mon Mar 21, 2005 1:53 pm
Hiya.
Forgot where I put the info, could you e-mail me teh infoyou used to have on your old MZ web site on carb set up please.
keithcross55@hotmail.com
Ta
Postby oldboyonrgv » Tue Mar 22, 2005 3:54 am
Ahhh , I was looking for the same thing ... I will have a look on the home P.C tonight.
oldboyonrgv
Postby oldboyonrgv » Thu Mar 24, 2005 5:44 am
Nope its gone !! sorry, I could probably remember though .
oldboyonrgv
Postby oldboyonrgv » Thu Mar 24, 2005 9:45 am
carb modifications. The mixture screw gets backed out(holeshot performance recommends 7 1/2 turns out from lightly seated),the main jet isn't adjustable, you replace the 130 main jet from the left side (as you're sitting on the bike)carb with a Kehin 135 and screw it in all the way tight. The midrange jet needles (both sides) get raised 1 notch, (this means the cirlip goes in the second groove from the pointy end) cut 2 coils from the constant velocity slide spring (right side)and re-install cut side down. Be sure to line up the diapraghm correctly, there is a little tab on the edge of it that fits into a recess cast into the top of the carb. At low altitude (below 5000 feet), you can drill the right carb's main jet with a #51 drill bit, just twist it between your fingers, no need for the drill press and re-install with a new P/N 90-20.142 crush washer. For around town riding this last step isn't really nessesary, you'll foul plugs more often and you should definatly keep a stock main jet (P/N 90-20.146) handy if you plan on doing any riding up in the mountains. The sync screw on top of the carb bank controlls the point after the low speed carb carb starts opening that the high speed carb begins to open, crank it in a turn or two so that as you twist the grip, you'll feel the freeplay take up, then the low speed carb start to open, then the added resistance of the high speed carb opening. You want the high speed carb to open just after the low speed opens, without as much of a delay as with the stock setting. This obviously needs to be set with the carbs reinstalled on the bike before the gas tank is replaced. Lastly, if yor bike is a Skorpion (Sport, Traveller, Replica Etc., not a Mastiff, Black Panther Etc.) Remove the black rubber snorkel from the top of the airbox. Of course, all these modifications are recommended for closed course, racetrack use only. Wink.
oldboyonrgv
Postby oldboyonrgv » Thu Mar 24, 2005 9:48 am
By the way, You can also drillout the air damper hole on the CV side (its the hole next to the needle) to 4MM, this allows the air to move faster so the slide comes up qucker. and I also recall installing a larger pilot jet, but there again I was running a race exhaust.
oldboyonrgv
Postby keithcross » Thu Mar 24, 2005 11:31 am
All usefulstuff. As Iamgetting aspare set of carurettors (£20 froma guy I brought some gear off of on EBay) I might tryout some of the mods.
Any body else got tis on Carbs mods?
Postby F0ul_Oli » Fri Mar 25, 2005 2:47 pm
This mod looks really good - but I think I'm going to have a go at getting an exhaust and a dyno jet adaptor sorted out first.
How much does this affect the fuel economy?
F0ul_Oli
Postby Whysub » Sat Mar 26, 2005 8:35 am
F0ul_Oli wrote:How much does this affect the fuel economy?
Who cares? If I wanted fuel economy, I'll ride everywhere at 50 mph, or buy a CG125.
Never bettered 50 mpg on either my Baggi or Sport-must be the way I ride them, as 40 mpg is the norm. I used to get 55 mpg from my GSX-R750 on my daily commute. But it was not even 10% of the fun I have now.
Moto Guzzi V1200 Sport
Honda CBR600 F-V
Suzuki SV650S -Y
Yamaha Vity
Suzuki Hokuto
Whysub
Postby boysie » Sat Mar 26, 2005 2:44 pm
Hi Kieth, yes mate I have also been running a similar setup for a number of years now, I seem to remember you have to order the pilot jet form a Yamaha dealer for an XT, as MZ don't supply pilot jet options, also you can modify your CV side main jet by drilling and taping it to accept Dynojet jets this gives more options for adjustment..
Oh yes, don't forget to drill some stonking great holes in the airbox;-
boysie
Postby keithcross » Sun Mar 27, 2005 1:00 am
Cheers to all. Boysie. when we gunna see your bike now its had te engine mods done?
Postby F0ul_Oli » Sun Mar 27, 2005 6:27 am
Reason Im asking is I wanted to know if it was a huge percentage or just a couple of MPG.
One of the basic laws of modification is that getting more power involves burning more fuel. My brother modded his smartcar and this knocked his fuel economy from 64mpg down to 34mpg! Quick though!
F0ul_Oli
F0ul_Oli
MPG and tuning
Postby oldboyonrgv » Mon Apr 18, 2005 9:26 am
F0ul_Oli where did you get that from ? getting em to run right makes them more economic as they are more efficient so you dont have to use so much throttle for the same result.
its only when you tune for speed you start to have an effect on the economy.[/quote]
oldboyonrgv
Users browsing this forum: Google [Bot] and 13 guests
