new US MZ owner
Re: new US MZ owner
Postby MuzTruckstuff » Wed Jan 16, 2008 6:57 pm
Hi, I'm also a new MZ owner. Got a 1998 Mastiff last month with about 8500 kilometers on it. For those interested, it has a headlamp unit off an early Triumph Bonneville. The originals were much the same as peeholes in a snowbank. I've been lurking around here and then a friend, frederickflintstone, got a Baghira, joined up and revealed himself, so here I am.
I'm kind of a scrounging sort and usually can source most anything...if I have time. So,here's the word on key blanks for Baghira/Mastiff. The Ilco number for a Volvo is bogus. I know, I tried it. BOY! It's close! but if you want it right without any hassle, go down to your local KTM dealer and buy a blank for one of the 950's. Probably about $9 each, pricey, but it's nickel plated brass has the rubber cover on it. Quality! You can also go online and find a cheap steel blank for a KTM if you can't stand having the rubber cover that says KTM on your MZ. Personally, I'm going to use the KTM key for riding and put the original key away with all the original docs. Seems a good bunch here to be around
Paul
MuzTruckstuff
Re: new US MZ owner
Postby DAVID THOMPSON » Wed Jan 16, 2008 9:41 pm
if you know the cut number of your mz ori key the same cut number in a ktm or buell may fit
and now i know what the problem with the volvo key is its close
ar dave
Re: new US MZ owner
Postby MuzTruckstuff » Thu Jan 17, 2008 11:42 am
Hi Dave,
The Ilco blank is VERY similar, but excessively long which is no problem,still it simply is a "rig" job and thus subject to problems, IMHO. I couldn't find a key code on the original key for my Mastiff without tearing the rubber cover off. I wasn't willing to do that, so I simply had a reputable locksmith here in town (who also comes to the house, unlike doctors) and test the key and adjust as necessary (which wasn't necessary). It's very possible that KTM and MZ key codes are alike, but at $9 a shot for blanks, I'll go with duplication. My intent was to preserve the original, in any case.
Paul
MuzTruckstuff
Re: new US MZ owner
Postby jackazz2 » Thu Jan 17, 2008 2:48 pm
looks like it works pretty good to me. key is all the way in and the switch is obviously in the on position.
if you own an mz you had better get used to "rigging " fixes if you want to ride the thing.
jackazz2
Re: new US MZ owner
Postby MuzTruckstuff » Thu Jan 17, 2008 5:55 pm
Did a little additional research on the key thing (hope this is the last post on it). Here's an interchange on the different bikes that use the same key as the Baghira/Mastiff. You can either source a key blank through a brand dealership or use the Ilco blank #X270-TCM1 via this list. There's no need to "rig" anything regarding the keys. If you're good with what you got, go for it. This is just for information I got off the Ilco website. Paul
Key Blank Interchange
Ilco X270
Ilco EZ TMC1
Silca ZD24RDP
Aprilia
1996 - Present Motorcycles and Scooters.
BMW
2007 G650 XCountry, XChallenge, XMoto
1997 - 1999 F650 (Aprilia)
Buell
2000 - Present Blast
2000 - Present Firebolt
2003 - Present Lightning
2006 Ulysses
Cagiva
99-up
Derbi
1999 - Present. Most models.
Italjet
1996 – up
KTM
1996 – up
Malaguti
1994 – up
Moto Guzzi
1995 – up most models
MZ
1994 – up
Piaggio
Triumph
1997 – up Most models
Yamaha
1997 – 2001 Zuma scooter
MuzTruckstuff
Re: new US MZ owner
Postby frederickflintstone » Sun Apr 06, 2014 3:43 am
After a very long hiatus from riding, I just ordered a set of tires and battery for the bike. hopefully I can have it back on the road by the beginning of May.
I have been going to sell this bike for several years and for one reason or another did not. I figure the bike will be easier to sell with fresh tires and battery, so I will see if I can have some fun with it.
frederickflintstone
Previous
Users browsing this forum: Bing [Bot] and 7 guests
