Running perfection
Running perfection
Postby Eomund » Sat Aug 08, 2020 5:53 pm
https://imgur.com/gallery/3rXqEnh
Got her running perfect. She's nearly done and legal. I changed the front tire last night. Gonna change out the rear tire tonight. Then the DMV to get plates.
Eomund
Re: Running perfection
Postby DAVID THOMPSON » Sat Aug 08, 2020 8:55 pm
after all that noise i remember why i switched to 4 cycle
its all that kicking it takes to get a 2 smoker to start
my weed eater is electric also
Postby Puffs » Sun Aug 09, 2020 3:47 am
Congrats Eomund, on finally receiving that float you ordered! Is that an original float?
Regardless, I'm not convinced the carb is tuned entirely optimal, and I would still go back to the standard settings on level height, jets & needle.
On the noise, two strokes do not necessarily have to revved to the max, and a well adjusted MZ will start with 1 kick, 2 at most.
Postby Blurredman » Mon Aug 24, 2020 8:29 am
Agree with Puffs-
My Mz's start up in just two or three kicks- and that's without doing the stupid 'MZ starting technique'.
My Suzuki two stroke normally takes 3 or 4 kicks to start (more than the MZ) but with low compression at 6.5:1 it isn't really an issue- unless you're on the trails and already tired out.. :lol: :lol:
