Speedo
Posted:
Fri Jun 03, 2022 12:25 pm
by mzsrus
Hello
Any ideas
Speedo not work on my mz1000s
Everything else does-on start up the speedo moves as normal
Notused for ten years now
Sensor on back axle if it is that works fine
Checked on other 1000
Was areplacement speedo from Grahams
not actually used since full service and new clocks back in 2013
any ideas
Re: Speedo
Posted:
Sat Jun 04, 2022 5:48 am
by DAVID THOMPSON
dirty contacts in wire harness
some of the plugs in my rt125 have been replaced with Anderson power poles
or soldered due to the quality of the plugs
the plug at the voltage reg just milted into a pile of junk
oh the fun of keeping an electric powered motorcycle running
Re: Speedo
Posted:
Sun Jun 05, 2022 2:46 am
by Puffs
Re: Speedo
Posted:
Sun Jun 05, 2022 7:02 am
by MJ310
Can you use the clocks off one of your other bikes to see if it's a clocks/wiring fault? I know it's a pain to strip down but I think it will be your best bet. If you need a hand give me a shout.
Re: Speedo
Posted:
Wed Jun 08, 2022 3:37 pm
by mzsrus
Swapped sensors
Swapped clocks
Still everything works apart from Speedo
Frustrating
Re: Speedo
Posted:
Thu Jun 09, 2022 10:28 am
by MJ310
Looks like you might have a wiring fault, try disconnecting the plugs from the ECU and give them a good shot of contact cleaner and go through any part of the loom that might have an effect.
