Engine struggles/sputters at high RPM
Postby RickBlaine » Mon Oct 30, 2006 6:20 pm
I actually did try that, Wonky. It didn't seem to matter what i connected or disconnected!
RickBlaine
Engine Struggles
Postby basser23 » Tue Oct 31, 2006 8:18 am
Chayanne,
I must be ignorant...you mentioned draining the float bowl, and the gas
goes from clear to yellow orange? Is the "clear" water or gas?
Seems it would be water....what am I missing here..too early to think..
Chip
basser23
Postby phlat65 » Tue Oct 31, 2006 10:21 am
water will alway settle to the bottom, it is heavier than petrol.
Postby Wonky » Tue Oct 31, 2006 11:41 am
RickBlaine wrote:I actually did try that, Wonky. It didn't seem to matter what i connected or disconnected!
OK! Sounds like water to me too....
Wonky
Update
Postby RickBlaine » Thu Nov 02, 2006 6:44 pm
So, it turns out it wasn't water:
I had a mechanic take a look at it this week, and he found that the spark plug was fouled up because the carbs were soaking it with fuel . . . (so they cleaned the carbs, which is what I started out to do in the first place) . . . but the reason the bike wouldn't start was because it had lost compression because the valves were all f*!@$d up. So they fixed that, too.
Almost $400 later, I'm psyched to pick up my bike tomorrow and see what it feels like to ride one of these bikes with an engine that *works*!!!
And at $90/hour, I'm more committed than ever to doing as much of my own wrench work as possible!
Thanks to everyone on the board who offered helpful words! :smt023
RickBlaine
engine sputters
Postby basser23 » Fri Nov 03, 2006 11:12 am
Rick,
I wonder how your valve were all f***ed up? Were they not closing?
Did they give you an explaination? Curious.....
Glad to hear its running again though..
Chip
basser23
Postby RickBlaine » Fri Nov 03, 2006 1:14 pm
They said intake valves were way too tight, and exhaust valves were way too loose.
RickBlaine
Postby Wonky » Sat Nov 04, 2006 5:53 am
Tight valves will indeed cause loss of compression and they will burn out quicker. They sound honest and they have carried out the correct work. At least you now know what to look for in the future...good luck with it buddy!
Wonky
Re: Engine struggles/sputters at high RPM
Postby cruise36_36 » Sat Dec 29, 2007 9:31 pm
MINE DID SAME...DRAIN FUEL BOWL AND TANK...JUST CONDENSATION IN TANK... :-D
cruise36_36
Previous
