rt fork seals
rt fork seals
Postby robert mack » Thu Jul 23, 2009 2:01 pm
hi all :smt006
i think my fork seals are gone on my rt. how hard or easy is it to change them and the fork oil???
mucho grando
robert
British by birth,Scottish by the grace of God.
robert mack
Re: rt fork seals
Postby Jamie » Fri Jul 24, 2009 3:43 am
Not too bad, no special tools required.
Just take your time, the manual helps.
:smt006 Jamie
Jamie
Re: rt fork seals
Postby robert mack » Tue Jul 28, 2009 4:50 pm
done the seals tonight, changed the oil but theres a hissing noise when i put pressure on the bars????
robert mack
Re: rt fork seals
Postby rodge70 » Wed Jul 29, 2009 3:00 am
you may be confusing the hissing sound with the oil swishing around but you could try some soapy bubbles around fork caps,top of seals and, i'm assuming the damper tube bolts at bottom of legs which normaly have a sealing washer.
rodge70
Re: rt fork seals
Postby robert mack » Wed Jul 29, 2009 3:50 pm
hi
i think it may be just air in the oil as there is no leaks and the seals are fine. the new fluid has lifted the fork up about an inch :smt023
robert mack
