Little MZ Content: CCM 604
Postby MZCountryRider » Mon Jan 21, 2013 5:24 pm
Yesterday I went to a vintage motorcycle swapmeet fully committed to not buy anything unless it was something for my MZ Saxon Tour engined ATK 604 project. Didn't even drive the van up so I wouldn't be tempted. That plan went right out the window as soon as I saw this CCM 604e Trail sitting there for sale at $785. Walked around a bit to think about whether I should buy it or not and how it would fit into my plans if I did. Decided to pull the trigger and gave the seller a deposit, will pick the bike up on Tuesday. Comes with all of the "missing" bits and some spares as well. The bad, is it has no compression.
The engine is basically a larger version of the Rotax 504E used in MZs and nearly identical to the one originally in my ATK, so engine parts are no mystery. Seems to be pretty good parts support via the internet for the rest too.
Still trying to find contact information for CCM though, I don't have any documentation that tells me what year the beast is and I'd like to know. If anyone in the UK has any contact information for CCM, I'd appreciate it if you'd pass it along. Thanks!
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Re: Little MZ Content: CCM 604
Postby DAVID THOMPSON » Mon Jan 21, 2013 10:39 pm
check the timing belt
people run the crap out of these things
and never service the belt
Postby Skorpion » Tue Jan 22, 2013 3:42 am
As far as I can see there is no web site for CCM, but there last known/current address is here.
http://www.misterwhat.co.uk/company/207 ... ltd-bolton
This place seems to do CCM spares,
http://www.ccmmotorcycles.net/
Skorpion
Postby MZCountryRider » Tue Jan 22, 2013 9:02 am
Dave - The cam belt will be my first thing to check once I get it home today.
Skorpion - thanks for the misterwhat info. I'll try giving them a ring.
Charlie
'73 Guzzi Eldorado
'76 Guzzi I-Convert
MZCountryRider
Postby breakwellmz » Tue Jan 22, 2013 10:47 am
MZCountryRider wrote:Dave - The cam belt will be my first thing to check once I get it home today.
Hi
The cambelt is SO easy to change as well-15 minute job on the MZ.
I thought Rotax engines were very popular in Flat track racing over there.
http://thekneeslider.com/ron-wood-rotax ... torcycles/
Cheers
Postby DAVID THOMPSON » Tue Jan 22, 2013 11:53 am
the rotax motors were very popular in flat track
i think ron wood lists the years they were the winner
i went to the AMA museum a few years ago with the saxon tour
people were looking for the gift shop staff
i said there all out in the parking lot looking at my bike :-D
Postby MZCountryRider » Tue Jan 22, 2013 9:59 pm
Photos from today here: http://www.antietamclassiccycle.com/ccm_604/
The compression issue is the cam belt - a bunch of teeth are stripped off it it. Could be a combination of not changing the belt often enough and the engine having heavier valve springs. Next on the agenda is a leakdown test to see if the valves took a hit.
Charlie
'73 Guzzi Eldorado
'76 Guzzi I-Convert
MZCountryRider
Postby breakwellmz » Wed Jan 23, 2013 6:35 am
Hi
I seem to remember that the Rotax is one of the`clever`designs that doesn`t wreck to valves if a cambelt breaks/slips.
Fingers crossed,you might have got yourself a real bargain. :)
Cheers
Postby DAVID THOMPSON » Wed Jan 23, 2013 8:01 pm
they will if a high lift cam has been installed that makes the lift tooo much
and they like to strip the teeth off the belt if stiffer springs are installed
if you run it proper it makes a nice daily driver
ps the 504 is good the 600 rotax motor in the mz frame is way too much
for the frame .. i have rode a 600 in an atk and it is an animal but a bad idea
for the mz frame its just to much power
Postby MZCountryRider » Wed Jan 23, 2013 11:45 pm
Well... As it turns out, it's not a 604 after all, it's a 350! 79.5 mm bore, six-speed transmission, Dellorto PHF 34 carb. Doesn't matter one bit to me, still has more power than my old '77 Yamaha XT500 and weighs a bit less! :D
Charlie
'73 Guzzi Eldorado
'76 Guzzi I-Convert
MZCountryRider
Postby breakwellmz » Thu Jan 24, 2013 5:28 am
Six speed? :shock:
Postby DAVID THOMPSON » Thu Jan 24, 2013 7:54 am
SWEET that would make a nice runner big enough to do trips
right size to do town daily driving
ATK made one this size as well
Postby MZCountryRider » Thu Jan 24, 2013 9:53 am
Yep, six speed transmission.
Before I bought this CCM, I had been considering a late ('97-'02) ATK 350 that was on Craigslist down near Baltimore. But I already have an ATK and wanted something different.
Charlie
'73 Guzzi Eldorado
'76 Guzzi I-Convert
MZCountryRider
Postby breakwellmz » Thu Jan 24, 2013 1:08 pm
Postby iceman » Thu Jan 24, 2013 3:22 pm
This is the Harley I believe... viewtopic.php?f=12&t=6389
John Lennon
iceman
Return to 500 cc
