Has anyone
Has anyone
Postby funmonkee » Tue Mar 03, 2009 4:56 pm
fitted a rev gauge to their baggi? I just wonder becuase a month or two back I rev'd it hard on the bypass and it cut out...I realise that this was probably due to the bike cutting out since I was redline it...
funmonkee
Re: Has anyone
Postby kendo » Wed Mar 04, 2009 4:30 pm
Yes, i purchased a small tacho from M & P and bolted it to my to my top yolk. It is 2 inch dia with a 0 -- 7000 range and is connected to the + side of the coil and works a treat. There is a picture on this forum if you search for "tachometer" in one of my posts you will find it..
Kenny.
kendo
Re: Has anyone
Postby funmonkee » Wed Mar 04, 2009 5:44 pm
Thanks Kenny. I just need to know if I'm revvin it too hard.
Is this the same tacho ?
http://www.mandp.co.uk/productInfo.aspx?catRef=500365
Really enjoying the baggi. But I'm making mine more street fighteresque than sm :D
funmonkee
Re: Has anyone
Postby kendo » Thu Mar 05, 2009 11:48 am
Thats the one, just make sure that it is the correct one they send you as i had to return mine twice as they sent me a 0-- 16k which was no good and also a gear driven one which again was no good. Also check that it will do a single cylinder engine.
Kenny
PS - did you see the pic from my original post, i just drilled a hole through the top yolk at a position that cleared the webbing inside the yolk.
kendo
Users browsing this forum: Bing [Bot] and 63 guests
