- Screen shot 2012-01-18 at 10.22.49 AM.jpg (10.05 KiB) Viewed 3171 times
the XT gear is a 1:1 replacement.
T
I prefer the Raptor gear which is thicker and does not require the heavy mild steel washer between the gear and the bearing.
I consider that washer to a part of the problem itself.
Beware, that the index on this gear does not match up in the XTZ engine.
That is not important, tho, as the keyways of both shafts face each other when the alignment is correct.
