Skorpion Selenoid
Skorpion Selenoid
Postby jaywillie2912 » Fri Jun 13, 2014 4:27 pm
My Skorpion has a selenoid - Hitachi MS5D-361. Does anyone know where I might find one.
jaywillie2912
Re: Skorpion Selenoid
Postby edfmaniac » Fri Jun 13, 2014 5:56 pm
You don't need an exact replacement. Any 12v solenoid that will handle as many or more amps than the OEM unit and will slide into the rubber mount will work. Google your part number and you will find many solutions. Sounds like this Yamaha part will work but you may want to confirm before ordering. 4KD-81-940-00
Postby edfmaniac » Fri Jun 13, 2014 6:01 pm
Graham's can probably help you with some new old stock if you can't confirm the Yamaha part, or something that is guaranteed to fit at least. http://www.grahamsmotorcycles.com/2010% ... n_Menu.htm
Postby DAVID THOMPSON » Fri Jun 13, 2014 7:48 pm
Most any yamaha atv has same unit
Dave
