Baghira seat mounting
Postby HestonsRightNut » Mon Oct 19, 2015 6:19 pm
Hi all,
I recently picked-up a 2001 Baghira and am having trouble locating some of the seat mounting hardware.
The folks at Grahams Motorcycles (Taunton) are out-of-stock and I may have to resort to fabricating something up.
Could someone share pics and/or ideas on alternatives for items 5, 6, and 7 in the below image?
Thanks in advance for the assist
Jay
HestonsRightNut
Re: Baghira seat mounting
Postby dicgleason » Tue Oct 27, 2015 1:53 pm
Let me get this right, #5 is the sleeve through the seat, #6 and 7 are the washer and spacer to hold the sleeve in the seat. Are these the parts you need? A proper diameter piece of stainless steel or copper tubing cut and flared while installed in the seat should fix the problem. If its # 26&27, The seat "bolt" I found them on the wall at my local Japanese motorcycle dealership among all the other fasteners.
Good luck and enjoy the bike.
dicgleason
Location: Beautiful, Downtown Queen Anne, MD. "The town so great one county couldn't hold it."
Postby den » Thu Oct 29, 2015 3:09 pm
looks to me like 5/6/7 are ghost images,,looks like there the parts that fit in the tank,,items 27 and 26 are the only seat fasteners needed,or should you have posted a photo of the tank??,,have you no tank , are the gromets buggered or missing,
den
Postby HestonsRightNut » Sat Oct 31, 2015 1:58 am
dicgleason wrote:Let me get this right, #5 is the sleeve through the seat, #6 and 7 are the washer and spacer to hold the sleeve in the seat. Are these the parts you need? A proper diameter piece of stainless steel or copper tubing cut and flared while installed in the seat should fix the problem. If its # 26&27, The seat "bolt" I found them on the wall at my local Japanese motorcycle dealership among all the other fasteners.
Yep, these are the spacers that appear to go through the seat (I've already bought a set of replacement dzus fasteners). I'm going to first try this sleeve washer (http://www.mcmaster.com/#93762a200/=zgi35f) and a spacer. Failing that, I'll go with the flared tubing suggestion.
Thanks much for the reply!
Jay
HestonsRightNut
