SZR660 thermostat/cooling etc - pls need photo
Postby mmks » Sun Feb 19, 2017 9:21 am
Please, I need help.I am restoring SZR660 and do not know where to place the thermostat, I studied the pictures from the Internet, manuals pictures too, of course, but I still do not get it. When I put the thermostat in place by the images manual thermostat interferes side cover or front right fork.
I have not got the original tubing, so they can not follow by them.
Can someone put some pictures here and instead mount thermostat and tubing? Thanks.
Sry. for my english
mmks
Re: SZR660 thermostat/cooling etc - pls need photo
Postby DAVID THOMPSON » Sun Feb 19, 2017 12:59 pm
Look here for drawing from parts book
http://www.grahamsmotorcycles.com/web/M ... diator.htm
number 39 about the middle of the page
this is for mz the book for szr may be different
i will add a picture of my traveller later as i have the lower faring off but it is stored
in a small room and needs backed outside to see it all
Postby mmks » Sun Feb 19, 2017 1:49 pm
thank you very much
I found some more pictures, but everyone from all different (Some users put the thermostat between water pump and radiator). On the PC's screen I think you know, but I was helpless to motorcecle. Now I know that a radiator is not a steel tube that connects the silicon tubing between the thermostat and the engine
mmks
Postby dandywarhol » Sun Feb 19, 2017 5:45 pm
I sent you a SZR manual in a PM
Alan
Whale oil beef hooked
dandywarhol
Postby mmks » Mon Feb 20, 2017 2:09 pm
Gentlemen, thank you very much, but I have a manual. Maybe (maybe some), is a problem for me, but I can not help manual. drawing pictures on manual are less accurate. The biggest problem is that I have no original hoses, so I can not set that as a "Lego". I do not know the position of the thermostat vs holder sidecover / headlight etc.
I think the creator of PAS took thermostat that found on the shelf and used it because none out / entrance do not aim at the right direction.
mmks
