rear sprocket
rear sprocket
Postby rcbikeracer » Sun Jan 22, 2017 12:08 pm
Had a traveller for a year, most of the time it seems to be in the wrong gear, ( this is probably me, being dumb ),. The hand book says front sprocket 15t, rear sprocket 39t, but my rear is 38t. So what is best for gentle touring on A roads and occasional dual carriage way use, ( I tend to respect speed limits ).
rcbikeracer
Re: rear sprocket
Postby DAVID THOMPSON » Sun Jan 22, 2017 1:24 pm
where i run 60mph is about it for posted speed
i use 16
43 on my traveller
Dave
some have said a 15 on the front puts to much pressure on the output shaft of transmission
Re: rear sprocket
Postby MZ in Oz » Tue Jan 24, 2017 4:51 am
Really depends on your style of riding,mainly touring and highway 15/39,commuting and running the hills 15/43, are what I found the best.
MZ in Oz
Re: rear sprocket
Postby rcbikeracer » Tue Jan 24, 2017 12:27 pm
So standard gearing is 2.6:1, whilst mine is 2.33:1, and 16/43 will be 2.68:1. It would seem that my gearing is to high, will go to 15/39 when I go back on the road this spring, cheers chaps :)
rcbikeracer
Re: rear sprocket
Postby rcbikeracer » Sun Apr 02, 2017 10:46 am
Put the gearing back to standard, 15/39 and took it out for its first run this year. B and A roads 50 to 70mph, felt relaxed and mostly seemed to be the rights revs for the right gear and speed. Unless my riding improved over the winter lay off, ( I don't think so). happy traveller :D
rcbikeracer
Re: rear sprocket
Postby Skorpion » Sun Apr 02, 2017 12:43 pm
The Skorpion's are definitely over geared as standard, 15/43 is the best for all round use.
Remember the engine is not a Thumper it has very little flywheel so needs to be revved to keep it smooth.
With the above gearing you can run 70-90 mph all day long, in the right country of course, :D
and better in town due to less snatching in the transmission.
Skorpion
Re: rear sprocket
Postby handsomejackuk » Fri Jul 21, 2017 3:03 pm
thinking on running 16 / 43 on my baghira as i have 16 /45 at the moment and not enough top end...
any thoughts on this setup.... before i buy a new rear sprocket ?
handsomejackuk
Re: rear sprocket
Postby Henry74 » Tue Sep 05, 2017 5:30 am
I never topped more than 140-143 kph on standard 15/39 on my tour.
traffic work is a pain. Yesterday I installed 15/43 and the bike is transformed now.
I can now use the 5th 130+.
Alas I didn't have a stretch of road completely by myself so I couldn't test it 140+
Henry74
Re: rear sprocket
Postby LAkevin » Thu Oct 12, 2017 10:18 am
As long as we're on the subject of sprockets, where are you guys getting your sprockets and chains? Would love to replace mine on my 98 Mastiff. Getting a little signs of hooking.
Kevin
Los Angeles
96 MuZ Mastiff
43 BSA WDM20
60 Norton Dominator 99
80 Guzzi Lemans 2
00 Guzzi Quota
LAkevin
Re: rear sprocket
Postby DAVID THOMPSON » Thu Oct 12, 2017 10:56 am
i sent you a pm ..log in so you can see you have mail
Re: rear sprocket
Postby LAkevin » Thu Oct 12, 2017 12:28 pm
Thanks Dave!
96 MuZ Mastiff
43 BSA WDM20
80 Guzzi Lemans 2
00 Guzzi Quota
LAkevin
Re: rear sprocket
Postby DAVID THOMPSON » Thu Oct 12, 2017 3:10 pm
THE DETAILS
got my last set at here he does bicycles and is esjot usa
NOTE the fax number is the same
Thorsten Schaette
ThorUSA
3550 North Union Drive
Olney,Il 62450
USA
Tel. 800 222 8356
Tel. 618 395 3840
Fax. 618 393 2956
Email: thorsten@thorusa.com
http://www.eurocycleusa.com/
EuroCycleUSA
3550 N Union Drive
Olney Il. 62450
tel:618 393 6300 fax:618 393 2956
Copyright © 2012 email. All rights reserved.
NOTE CLICK ON MAIN PAGE AND IT TAKES YOU TO ESJOT WEB SITE CATALOG PAGE
THEN ASK THOR USA HOW TO ORDER
THIS IS STILL GOOD INFO AS FAR AS I CAN TELL Dave july19 2019
