Tachometer
I would like a tach. on my Baghira. Has anyone found a simple solution? Thanks in advance.
https://www.mzriders.com/
Garf wrote:Oh yeah, and slipstream sell 'em. Sorry Wonky I forgot that you had set up a supply when you were building the STMZ.
Is she completely finished yet with your motor and carb installed yet ?
You have been so quiet I was beginning to think you had taken your fat wallet and moved to Mexico![]()
Cheers
Garf
kendo wrote:Hi,
I purchased 1 from M and P for my Baghira, it took a bit of doing but after a few phone calls to M+P and their supplier i eventually got one. I mounted it onto the top yolk and connected up 4 wires and away it went with no problems. I you are ordering one make sure you ask for one that has a 60mm black face, goes from 0-8000 rpm has a chrome body and is compatible with a single cylinder engine, if they say that they dont do one then tell them that they do and to look a little bit harder. If you are getting no joy then let me know and i will give you my name and then they should be able to source it from my last order.
Kenny.
