billet
PostPosted: Thu Oct 23, 2008 9:38 pm
by credit
looking for billet rear brake and gear set any suggestions
Re: billet
PostPosted: Fri Oct 24, 2008 1:01 am
by Bill Jurgenson
what is that supposed to be?
Re: billet
PostPosted: Fri Oct 24, 2008 5:29 am
by handsomejackuk
bill,
Billet refers to a cast semi finished product. this can be machined into any shape. particularly nice if cnc machined.
http://www.billet.co.uk/index2.html?home.html~mainFrame
hope this helps Bill..
Jak
Re: billet
PostPosted: Fri Oct 24, 2008 12:04 pm
by Bill Jurgenson
I know what billet means and it is not necessarily cast. Usually not in fact. Could also be from extruded solid. Billet parts are usually machined from forgings. Casting can be done so accurately that almost no machining is necessary. A completely different question is that of material grain and stress zones. That is where forgings are generally considered superior.
Whatever.
The question referred billet parts for the rear wheel but what parts?
Chainwheel? Pratically all good chainwheels are (CNC)machined but calling then billet would be gilting the lily.
And a billet rear brake caliper? On a Skorpion or indeed any street bike? That would be definitely gilting the lily, wasting more than enuf money for nothing.
The question was vague to say the least.
Re: billet
PostPosted: Fri Oct 24, 2008 1:16 pm
by handsomejackuk
ooooooo
handbags at dawn
:smt005
Re: billet
PostPosted: Fri Oct 24, 2008 9:11 pm
by credit
I bent my rear brake lever and would like to replace it with a nicer better one ... ie billet while I'm at it I would like to replace the rear lever too
Re: billet
PostPosted: Sat Oct 25, 2008 4:21 am
by handsomejackuk
credit,
if you need advice about material grain and stress zones better contact Billy the Billet he seems to have all the answers :D
Jak
Re: billet
PostPosted: Sat Oct 25, 2008 12:45 pm
by Linegeist
handsomejackuk wrote:credit,
Jak
Hmmmm. I've always found Bill to be full of correct answers. In fact the bloke's a mine of useful information that he shares with people all over the place. He's certainly helped me out on more than one occasion - and I'm supposed to be a qualified engineer......
Is that what you meant?
Re: billet
PostPosted: Sat Oct 25, 2008 1:40 pm
by credit
no just want to know what parts will swap out so I can order them
Re: billet
PostPosted: Sat Oct 25, 2008 2:56 pm
by Linegeist
Re: billet
PostPosted: Sun Oct 26, 2008 3:42 am
by Bill Jurgenson
You seem to be talking about brakes levers. There are none that fit into the Grimeca hand pump without machining.
Not billet, cast, but more than good enuf: the foot brake lever from a Yamaha TZR/SZR fits onto footpeg.
replica peg-right side.jpg (71.54 KiB) Viewed 3987 times
This is such a Yamaha lever on an original MuZ Skorpion Replica peg fixed to a standard Skorpion Tour bracket.
Probably most any Yamaha lever will if the bolt hole for the plunger is at the right place. In fact probably most any brake lever, regardless of marque, will fit the peg. The only question is where the bolt hole is.
Re: billet
PostPosted: Wed Oct 07, 2009 11:33 pm
by Roadstergal
Which levers fit with machining?
Re: billet
PostPosted: Thu Oct 08, 2009 7:32 am
by iceman
Dam,you're dieing to use that lathe... :-D
