Starting speed?
Starting speed?
Postby Jurrien » Sun Feb 13, 2011 3:42 pm
my skorpion won't start.. I am wondering if the starter motor is giving the engine enough speed? I don't think so but i haven't heard any other 660 start, ever. So I don't know for sure.
Here is a short clip, can anybody tell me this is the normal speed or is it too slow? http://www.waarbijaardbei.nl/mz/MVI_0276.AVI
Jurrien
Jurrien
Re: Starting speed?
Postby angustoyou » Sun Feb 13, 2011 4:53 pm
That's the same (or even slightly faster) as the turnover speed on my Baghira.
Mine fires if I :
Turn the fuel on, blip the throttle twice, use full choke and no throttle at all, and hit the starter. If it hasn't fired after 3 or 4 seconds, stop and then try again, and she normaly fires straight up. She's usualy stood for between one and three weeks between starts.
Tried some carb cleaner? Never used it myself, but it seems popular for stale fuel.
angustoyou
Re: Starting speed?
Postby Fluffy_Dog_1018 » Sun Feb 13, 2011 7:31 pm
My 660 Traveller sounds the same i.e. your cranking speed is just fine. Tough to diagnose without more information (has it sat etc.) but I would do the normal troubleshooting. You need spark, fuel, and compression. Fuel is an easy one to check. Drain the bowl... is there fuel in it? Give a good puff of starter fluid in the airbox and crank it again. If it doesn't turn over with starter fluid likely you have no spark or very poor compression.
Somthin ain't right.
1982 Yamaha Maxim SOLD
2001 Suzuki SV650 SOLD
2001 Kawasaki Concours SOLD
1983 Honda CB650SC SOLD
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Re: Starting speed?
Postby basser23 » Mon Feb 14, 2011 11:33 am
Besides the "film" critic post,your engine start speed is fine..same as my Skorp.
How do these turkeys post on this site..mad buggers
Re: Starting speed?
Postby droy » Mon Feb 14, 2011 2:34 pm
Do you still have the fuel pump in place? Removing that can be very helpful. Do a search - numerous posts on the subject.
Doug
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Re: Starting speed?
Postby Jurrien » Mon Feb 14, 2011 2:41 pm
Ok, thanks for the reply's. No worries, I'll have it working again, I was just wondering about the cranking speed, if feels so slow.. But now I know it's just normal.
Jurrien
Re: Starting speed?
Postby Skorpion660 » Mon Feb 14, 2011 5:53 pm
Jurrien wrote:Ok, thanks for the reply's. No worries, I'll have it working again, I was just wondering about the cranking speed, if feels so slow. But now I know it's just normal.
Don't forget you're turning that big 660 cc piston over so it does sound as if it's struggling. I had a 1064 cc Guzzi and the battery was trying to turn over 2 big pistons with a much larger battery than the standard Skorpion one. Most people have found that removing the fuel pump and putting fuel tap to off and letting the float bowl run dry before laying bike up makes starting easier with a fresh float bowl of fuel. Also replacing standard battery with larger amp/hours helps, there are posts on this.
I had a Kawasaki ER5 for a couple of years and was always impressed how easily it started even after months of no use then I realized that at the end of the day It only had to turn over 2 piddly 250 cc pistons.
Terry
Skorpion660
Users browsing this forum: Bing [Bot], Google [Bot] and 42 guests
