dog bones
Posted:
Sun Jan 15, 2012 3:38 pm
by hutchy
Hi, I'm wanting to lift the backend of the baggy, do I need shorter or longer dog bones? cheers........hutchy
Re: dog bones
Posted:
Mon Jan 16, 2012 1:34 am
by Bill Jurgenson
I would set myself on the ground beside the bike and take good look and think...
shorter ones of course.
Re: dog bones
Posted:
Mon Jan 16, 2012 4:20 pm
by hutchy
Thanks Bill, the font of all wisdom as usual.
I did think that i would need the shorter dog bones but thought that i would get this confirmed before fabricating some new ones.
While I have your attention Bill, can you please tell me which replacement part you use for the rubbish balancer gear, am I right in thinking it comes off a number of machines-newer xtz660 and raptor
Thanks for your help.......Hutchy
Re: dog bones
Posted:
Mon Jan 16, 2012 4:48 pm
by Skorpion
Hi hutchy.
Shorter ones are correct, you can buy these from GRAHAMS, they are genuine MZ parts.
Three lengths Standard 142mm? & 135mm-127mm
EDIT
Sorry the above is for the Skorpion Only.
Re: dog bones
Posted:
Tue Jan 17, 2012 8:25 am
by Old Dog
Remember it will effect the sidestand, the bike will lean over a lot more, well at least my Skorpion does, but it sharpens the cornering somewhat.
Re: dog bones
Posted:
Tue Jan 17, 2012 4:26 pm
by hutchy
thanks for the help......hutchy
Re: dog bones
Posted:
Tue Jan 17, 2012 6:32 pm
by basser23
lowering the front would have the same result,,,not too much though....10mm maybe
Re: dog bones
Posted:
Wed Jan 18, 2012 5:28 am
by Bill Jurgenson
- Screen shot 2012-01-18 at 10.22.49 AM.jpg (10.05 KiB) Viewed 3172 times
the XT gear is a 1:1 replacement.
T
I prefer the Raptor gear which is thicker and does not require the heavy mild steel washer between the gear and the bearing.
I consider that washer to a part of the problem itself.
Beware, that the index on this gear does not match up in the XTZ engine.
That is not important, tho, as the keyways of both shafts face each other when the alignment is correct.
