trailtech vapor or Koso DB01R
Postby handsomejackuk » Thu Sep 13, 2012 3:39 pm
has anyone fitted one of these as very tempted... have noticed a lot of Raptors seem to have the vapor fitted... looking for a xmas present for this year and have been wanting one for ages...
http://www.moorespeedracing.co.uk/koso- ... peedo.html
Re: trailtech vapor or Koso DB01R
Postby edfmaniac » Thu Sep 13, 2012 4:53 pm
The Vapor is a nice product if they worked out the rpm sensor wire for the Yamaha 660. It needs a resistor in line to work right but I went and bought the one recommended for the fix and still couldn't get it to show a stable reading. Go with the black "Stealth" unit as the silver finish on the standard model is poor quality and opt for the nice housing/mount that they offer.
Postby handsomejackuk » Thu Sep 13, 2012 5:01 pm
edfmaniac wrote:The Vapor is a nice product if they worked out the rpm sensor wire for the Yamaha 660. It needs a resistor in line to work right but I went and bought the one recommended for the fix and still couldn't get it to show a stable reading. Go with the black "Stealth" unit as the silver finish on the standard model is poor quality and opt for the nice housing/mount that they offer.
do you have any pics of yours installed ? did the water sensor work ok too ?
Postby rodge70 » Fri Sep 14, 2012 7:32 am
@edfmaniac,
have you wired the resistor wire straight to coil,think you then need to program ppr bit in manual.if i get 5mins willlook to see what i set mine atworked for me
al,i would go with the housing too as all the mz lights will fit in it,just need to add an overtemp warning light or you can use the settings on the vapor.
everything included in the kit for the water connection as well,did mine to side of cylinder head.
rodge70
Postby edfmaniac » Fri Sep 14, 2012 9:27 am
Mine has a homemade, very minimal mount that is temporary until the final stages of my project come together. I haven't felt the need to hook up the water temp function.
Postby handsomejackuk » Fri Sep 14, 2012 1:31 pm
Thanx rodge... we are going 2 fowlers tomorrow leaving here 10.00 will be in fowlers 11.30- 12.00 foned fowlers for the choke knobby 57 quid... mad....will get trailtech for xmas hopefully
Postby rodge70 » Sun Sep 16, 2012 9:18 am
oops,sorry been to z1oc meet at the weekend :oops:
rodge70
Postby handsomejackuk » Sun Sep 16, 2012 1:50 pm
have you got a Z1 then....??
you may know Dai griff lives by me got one,, and Steve tucker, Dean carpenter... they got Z's too
Postby RiverDrive » Fri Sep 21, 2012 11:03 am
Don't get the Vapor if you want a Tach
The ambient temp also reads about 10%F too high
Other functions work fine, but I wished I had just gone with a bicycle speedo and forgone the rest.
01 Sport Cup Gone Sport
RiverDrive
Users browsing this forum: Bing [Bot] and 22 guests
