Camshaft split in two
I checked spark and fuel. There was spark and fuel, but the spark plug was covered in a greyish oil (looked like water and oil). Compression test showed 0 compression. I should note that i was absent minded enough to not check the spark plug before going on my ride, and when i took out the plug noticed the crush washer was not crushed. So, the PO had not torqued the spark in.
I took apart the top end and what do ya know the camshaft was broken in two pieces (see attached photo). Checking the valves, cylinder, and piston, they all looked fine.
In addition to what i should look out for before installing a new camshaft, does anyone have any ideas how something like this might happen? Any info or advise appreciated.
Thanks all.
Bueller
