Removing rear tail cowl on an 03 baghira?
Postby wrassemeister » Tue Oct 11, 2016 9:57 pm
Hi guys just got an 03 baghira, I'm trying to remove the rear tail section ( the part thats part of the rear fender)... its pretty stuck in there and won't come out going up above or going down under the subframe... is there a trick to getting it out?
wrassemeister
Re: Removing rear tail cowl on an 03 baghira?
Postby den » Wed Oct 12, 2016 12:33 pm
Just pull it out,,i think its bolted on via the rear hand rails,and reflector,,If you want to make your own tail tidy look at my video i made,,the templates uploaded here somewhere,
https://youtu.be/DJ3GotOdBpI
den
Postby wrassemeister » Thu Oct 13, 2016 9:17 am
Got it thanks
wrassemeister
