brake light
brake light
Postby TIME LORD » Thu Feb 22, 2007 3:46 am
Could any one help please,
my brake light had blown only the part when i press the brake but the light comes on as normal with the head light.
I have replaced the bulb but the brake light when pressed still does not come on.
Thanks For Your Help
Kind Regards
TIME LORD
Brake light
Postby Jimbo M » Thu Feb 22, 2007 6:41 am
Have you tried your brake light with your rear brake only (foot)?
If this works, it could just be the switch/sensor for the front brake lever.
I had a problem with mine (it just wears out!) £6 ish from BSA (MZ parts)
Really simple to fix!
If your brake light dosn't work on the rear then I don't know.
Jimbo M
RE brake light
Postby TIME LORD » Thu Feb 22, 2007 7:35 am
thanks for the info,
I did try the frount and back on the lever and the foot pedal and the light did not come on with the lights turned off, but with the lights on it does come on but does not get brighter when the pedal or leaver is used.
Kind Regards
TIME LORD
bs
Postby DAVID THOMPSON » Thu Feb 22, 2007 7:23 pm
rear switch= aprilia number on parts bag is
8124479
for rear brake light switch on my 2002 rt125
the front one is a bmw part
61 31 1 244 070
This part fits models listed for year 1981 maybe others
R80, R80ST, R65, R80RT, R80GS, R100/7, R100CS, R100RS, R100RT, R65LS
also fits 2002 mz rt125cc and 1995 saxon tour and harley davidson sprint from early 1970's
search word fbs rbs
Last edited by DAVID THOMPSON on Sun Feb 25, 2007 12:27 pm, edited 1 time in total.
BRAKE LIGHTS
Postby TIME LORD » Sat Feb 24, 2007 5:10 pm
I would like to say thanks for your help and give some more part numbers.
Yamaha Part
This number on the packet 5JH-H3980-02 and F20060830.
from web site http://www.beedspeed.com [A] 24 614 0030 & [A] 24 614 0040
This one comes with a wire attached and a cover but you can take them off and the switch is the same as the original SM part.
Gilera, Piaggio, Vespa parts
Part number [A]-24 614 0010 this is a metal one but it still fits.
I am still looking to get the back switch.
Kind Regards
TIME LORD
rbsw
Postby DAVID THOMPSON » Sat Feb 24, 2007 7:23 pm
[quote=from above post "DAVID THOMPSON"]rear switch= aprilia number on parts bag is
8124479
this was a replacement sent to me by the dealer where i bought the bike
and it fit mine
rt125 rearbrakeswitch
re brake light
Postby TIME LORD » Sun Feb 25, 2007 4:21 am
Sorry Dave, I was not saying yours did not fit but I could nt find a dealer that had some in the shop and was trying to be of help to others with more part numbers.
Kind Regards
TIME LORD
part
Postby DAVID THOMPSON » Sun Feb 25, 2007 12:25 pm
it fits a bunch of bikes try a ccm or atk dealer or a made in italy dealer
there may even be a ktm number for it
ar dave
rear brake switch fitting
Postby TIME LORD » Tue Feb 27, 2007 7:58 am
I have got the switch for the sm but was woundering how to fit it I can unscrew it but how do i get the brake line off with the ring.
Please see picture
picture of switch
MZ Rear Brake Switch.JPG (19.71 KiB) Viewed 8417 times
Kind Regards
TIME LORD
rear brake light
Postby Jimbo M » Tue Feb 27, 2007 8:52 am
I find it hard to believe that both switches could be bad.
Have you checked that your replacement bulb is twin filament (sometimes the simple things)
Jimbo M
swithes
Postby TIME LORD » Tue Feb 27, 2007 9:13 am
I have never replaced the back one in six years but the front one i have had at least one a year.
But could any one help with fitting the back.
Kind Regards
TIME LORD
rt125
Postby DAVID THOMPSON » Tue Feb 27, 2007 10:26 pm
on my rt the switch is also the bolt that holds the line on
remove switch and line comes loose then replace
and have a ton of fun getting it bleed of air after done yuk
re switch
Postby TIME LORD » Wed Feb 28, 2007 2:23 am
Thanks Dave,
So the the brass washer may be squashed to much and binding it up they must have over done it in the factory as i have never changed it before.
Thansks again Dave your a Star.
Kind Regards
TIME LORD
Return to 125 cc
