Brake pads??
Brake pads??
Postby ghostinthemist » Sun Mar 25, 2012 6:50 pm
Is there another bike that used thee same brake pads as 1974 mz ts 150 that would be readily available in america?
ghostinthemist
Re: Brake pads??
Postby therealche » Mon Mar 26, 2012 12:06 pm
front brake shoes for MZ TS150 is EBC 978 stocked by www.perfectbrakes.com rear for MZ/MUZ STREETBIKES - 500 Country - 93-98 (160mm x 30mm)
Also on eBay.com Item no: 230762085729
Also on ebay.com for some Ferodo FSB823 which are 160mm x 30mm item no 290671226263
Rear appear to be EBC 979 which are 140mm x 30mm cant find anything else that uses them, but again on ebay.com Item no 230762086463
But measure before you buy to make sure Ive got them right!
therealche
Re: Brake pads??
Postby Louis Mair » Sat Mar 31, 2012 6:39 am
The TS150 MZ has a 160mm drum brake at the front end. If you have the brake shoes, a brake and clutch re-lining specialist can glue new friction material onto them. If you can find such a specialist!
The same brake shoes were used (front & rear) on the TS250 MZ. The ETZ models use the same brake shoes for the rear brake. The Rotax-engined bikes would also count as honourary ETZs as far as brake shoes are concerned.
The books claim that the rear brake of the TS150 is smaller, implying that the shoes would be a different size. I think you will find that it is the same 160mm drum and the same brake shoes. But don't take my word for it!
In the Americas Brazil and Cuba are the most MZ-friendly countries. The TS250 (4-speed) model was sold in both Canada and the United States; the Rotax Country was sold in the United States.
Louis Mair has been different things to different people. Now I am a writer: http://www.mz301escocia.blogspot.com
Louis Mair
