Re: 1974 army MZ TS250 restoration project
![Post Post](./styles/prosilver/imageset/icon_post_target.gif)
Well impressed with your efforts - especially given that you have no garage to work in.
Keep posting and keep up the good work !!
https://www.mzriders.com/
Guesi wrote:On your picture there is a 5 gear clutch, so you need a 5 gear clutch extractor.
Also the front fork is from the 5 gear model, so maybe you have a TS 250/1 model ?
Or someone had changed these parts in the past......
Blurredman wrote:That clutch basket is a bit rusty but that shouldn't be too much of an issue.
By the way, the expense you pay on it now will be superficial, seeing as it is both MOT and Tax exempt. You'll be saving like £70 a year! I can't wait until some of my vehicles are exempt.. They should be anyway!.. I don't have a vehicle over 25 years old..
NVA250 wrote:Guesi wrote:On your picture there is a 5 gear clutch, so you need a 5 gear clutch extractor.
Well now, that explains a bit. Thanks!
I think this bike is very much a "bitza". I know the forks are from a 250/1, I added these as it had ETZ forks and wheel fitted when I bought it. The engine has the finned cylinder head from the early 250, so I was assuming it was the 4 gear engine. Annoying as I have bought a seal and bearing set for the 4 gear rather than 5 gear engine.
The engine has definitely been apart before and I don't suppose I'll know for sure until I've got the engine apart completely. Is it possible that someone has fitted a 5 speed crank in a 4 speed engine?
Guesi wrote:
If you find a round cover with 4 screws on the housing under the carb it is a 4 gear housing.
So you need oil seals for the 4 gear engine.
And putting a 5 gear gearbox into a 4 gear housing is not possible.
They did it on the "enduro" models like MZ ETS 250 G . But all the gearbox parts are different from the normal 5 gear speed box.
DAVID THOMPSON wrote:i rewired a BMW R50s in the front hall in 1975 have to do what i needed to get to work
it was too cold out side to work on it
Dave
