ETZ 125 spark problem
Hello. I have a ETZ 125. The problem is, that there is no spark so the engine doesn't start.
I have checked connections and it seems that they're ok. I have cleaned breaker points with sand paper, install a new NGK spark plug, checked ignition timing. But it still doesn't start.
What else could be wrong?
Can someone tell me, what connections ONLY have to be connected, that the engine starts (without lights, ignition switch,..), just the most important connections to start it up.
Thank you!
Thank you!
