Painting the Plastic
Postby RickBlaine » Sun Nov 05, 2006 9:42 pm
I have a '95 Skorpion Tour, and I've been pondering the possibilities of repainting the plastic bits for a more personalized look. I haven't quite decided what I want to do, but was wondering if anyone had any experience repainting these things, or advice as to what materials/processes work best...
RickBlaine
paint
Postby DAVID THOMPSON » Sun Nov 05, 2006 11:14 pm
check with a local pro paint seller for details
and some of the pannels may have a code that tells what plastic it is made from
krylon also makes a paint for plastic parts
and loctite makes a patch material under one of there brand names
ar dave
Postby phlat65 » Mon Nov 06, 2006 10:54 pm
they make many great products for automotive aplications. you will need an adhesion promoter, and if the part is flexible, they have additives to pake the paint flexible. stop in a local body shop, alot of painters are paid by the job and usually do side work. if you are flexible enough you can leave them as filler work and usually get a good deal. also the more prep you do, the more you save.
Postby Wonky » Tue Nov 21, 2006 8:37 am
Usually with plastics you will need to use a "barcoat" which is a flexible paint base coat. Once this has been applied then you can paint your required colour/s!
Wonky
