Once again, I learn a lesson the easy way!manumensa wrote:Hello!
All joint-papers have to soak in oil or grease. If the surfaces (crankcase and barrel) are OK no problem.
manumensa wrote:For joint the half-crankcases I use Hylomar, this sealant is good and clean it after for new re-build is very easy.
Saludos, Manuel.
