David, are we talking Sport or Tour?
If Tour, you can swap the clipons so that the clamps are at the back, making a somewhat more upright position.
If you are talking Sport, you will need to get other clipons as the originals are impossible: clumsy and far too wide.
In the picture at the top, you can see Tomasselli forge adjustable clipons. These are ideal but unfortunately no longer made and rather rare in 41mm. I was able to garner two sets over the years and pass them on to Skorpion riders who love them.
Personally, I use
Gilles GP Light which are the best on the market but not the most expensive. I have them under the triple tree on both the Skorpion and the SZR. Of course they can be mounted above the triple tree like the OEM parts on the MZ. in a similar price catagory (around 120€) are the welded clipons from
Boecker - sorry only in German but I could get them for you if need be. They are well made. I used the straight variety on the racer under the yoke.
Another good source for very well made classical clipons is
Motocicli Veloci. I get many items from Maurizio and can recommend his shop.
or
These can be had in 5, 10, an 15º angles and in any Ø between 30 and 54mm.
The bee's knees are the
Gilles Variobars but they are very expensive.
Of course there are other brands like Lucas or LSL, virtually all of them more expensive than the GP light while not as good. I would not touch the Telefix with a ten foot pole. They are dangerous.
As Bob noted, correctly set up, you rest on the wind "cushion" as soon as you are going fast enuf. You do not need very high bars. I personally think they are self defeating since they forceyour weight on your butt - or you thighs, which is much more strenuous than a correct position and begs a sofa-like seat. That in turn robs you of any control the high setup might have left over.
I do not make rearset brackets apart from those I made for myself. It is far too expensive for me to do. There once was a set marketed by
BikeWorx but I do not know if these are still available. I doubt it, tho.
One easy way to make custom rearsets is to use two lengths of 8mm flat alu, one each bolted to the frame and joined by the bolt holding the peg. They need to be slightly cranked of course. All you need is a hacksaw, one or two files, a drill of course, a vise and the aluminum. Shouldn't take more than an hour or two.
Or you can cut them from 8mm aluminum plate as I did the first time.
- rearset.jpg (69.81 KiB) Viewed 7127 times
A couple of drills and files. a scrollsaw and lot of patience.
Pegs and Lever(I need only the brake) can be taken from just about any rearset. Both Louis and Gericke market so-called racing pegs which can easily be adapted but you do need to turn collars for them at the lathe since thay are meant to go onto the fold-up hinges. I have such pegs on the SZR.
Maurizio above sells pegs etc separately for the brackets you make. Skorpion Replica pegs are very good and the Yamaha TZR/SZR brake pedal fits right on (yesterday's posting and of course on the SZR where it is original).
You do need to make a drawing/sketch first:
- right side.jpg (69.64 KiB) Viewed 7122 times
This is what I am using. Obviously, the leftside does not need the brake bracket.
For one customer, I mounted a set of Lucas for a Honda CBR900 he had by pressing in a threaded bushing from behind into the spacer collar:
- Lucas.jpg (65.05 KiB) Viewed 7121 times
Steel poprivet nuts would do just fine and two or three along the arc would make the height nicely adjustable.
I may be able to talk Gilles into making a bracket to fit but it won't be cheap!
