Reservoir bracket and tubing for Brembo PS16 pump
Postby djsbriscoe » Wed Nov 18, 2009 10:51 am
I'm looking for the part numbers and any guidance on what type/size reservoir and which bracket to use on a Brembo PS16 brake lever/pump.
Brembo PS16 brake lever/pump with 15ml reservoir
Is a 15ml reservoir enough for normal use?
Also what is the part number of the Brembo tubing that is normally used?
I am going to be fitting the lever to my skorpion traveller so any advice on which parts to use would be welcome.
Thanks.
David.
Electronics tech by trade.
djsbriscoe
