Pre-mix Ratio Help??????????
Postby rednexx1 » Sat Mar 06, 2010 4:50 pm
Hi aAll,
What premix ratio would you guys recommend for a TS250/1
At the moment i run 50 to 1 which seems to work ok,However could i be causing unseen damage?
rednexx1
Re: Pre-mix Ratio Help??????????
Postby Skorpion » Sat Mar 06, 2010 5:48 pm
Yes rednexx1
50to1 is the correct oil mix for a TS250/1,
if you are worried try 40to1 won't do any harm, or use semi-synthetic or even full-synthetic.
skorpion
Skorpion
Postby Mike G » Sun Mar 07, 2010 6:54 pm
You should stick to the 50:1 ratio as anything less will decrease the amount of petrol in the mix, weakening the mixture and possibly overheating the engine. I ran many 10s of thousands of miles on a TS250 and had no reliability issues except when I leaned off the mixture too much and it seized.
Mike
Mike G
