Electic issue
Electic issue
Postby Klots » Wed Sep 01, 2010 12:28 pm
Hi!
My horse is a MZ125 SM, year 2003
The problem is missing spark. Battery is full, fuses are well, kill switch is Ok, starter works great, but no spark! I have changed ECU, ignition coil, spark plug and i have noticed that two wires, that is going to stand swich, these wires are connected. I think they have to be separately, because otherwise there´s no point.
Have you any ideas?
Thanks for helping mate´s!
Cheers from Estonia
Klots
Re: Electic issue
Postby DAVID THOMPSON » Wed Sep 01, 2010 10:22 pm
the sidestand wires work relay 19 if it is not closed motor will not run
the one on my rt125 died a long time back
search site for relay19 or relay 19
Re: Electic issue
Postby Klots » Thu Sep 02, 2010 12:19 am
Thx m8.
Klots
Re: Electic issue
Postby Klots » Fri Sep 10, 2010 2:49 pm
Hey!
Next problem. I changed the gray relay and i got my bike motor work (in neutral position) BUT.... When i put on any gear, it dies?!? I have no ideas about that.
Klots
Re: Electic issue
Postby DAVID THOMPSON » Fri Sep 10, 2010 6:41 pm
is the netural lamp working
the netural lamp a diode and the handle bar stop run switch all work together to ground the green wire from the gray relay
making it power the bike
grounding the lug the green wire bypasses the side stand switch and the kill switch
if grounding the lug makes bike run then problem is in the sidestand switch or the diode is bad
in the middle of drawing is marked a diode item 31 if this is open or shorted it can cause problems
find a HAM RADIO OPERATOR THATS ALSO A BIKER he may be of help or know some one that can sort it out
its hard to trouble shoot thing that are 10,000 km on the other side of the world
mz rt125 Circuit diagram 001.TIF
4cycle rt sm sx fun -x 125cc wiring drawing
Re: Electic issue
Postby Klots » Sun Sep 12, 2010 2:13 am
To illiminate side stand switch, i disconnected it. If i pull gear on, the 2 wires are connected, like as kill switch does...Today i connect neutral blue wire to ground and try again. Thanks for help and i update if i have any news.
Klots
Re: Electic issue
Postby Klots » Wed Sep 15, 2010 3:52 am
mymethod worked but neutral light works all time. still looking for suggestions..
Klots
Return to 125 cc
