Mastif headlamps.
Mastif headlamps.
Postby nyarla » Mon Jan 31, 2005 4:00 am
Hi All.
I have just purchased an 02 plate Mastif to use on my commute.
The bike is great fun apart from the useless headlights.
Does anyone know of any easy way to upgrade these to something I can see with?
nyarla
Postby nyarla » Fri Mar 04, 2005 5:29 am
Ok so no ideas?
well it looks like a diet heavy in carrots is the answer.
Actually I`ve got another non moving question on a different site. I`ll see if I can post the link.
http://www.rib.net/forum/showthread.php?t=8930
I wonder if that works.
I don`t think anyone here can answer the question but at the moment you can`t be any worse than they are.
nyarla
lights
Postby Nobog » Fri Mar 04, 2005 9:18 am
nyarla,
I assume you have seen what I did with my Mastiff at:
http://www.geocities.com/kurkjl/
Jim
Nobog
Postby Dezmo » Fri Mar 04, 2005 1:57 pm
Hella Yella, coming ta getcha!
Dezmo
Postby Sourcer » Sat May 13, 2006 4:02 pm
Is it possible to adjust the headlight angle a little bit for correct aiming?
Sourcer
light
Postby DAVID THOMPSON » Sat May 13, 2006 6:37 pm
i replaced one on an old bmw a friend uses for a daily driver with
a complete unit for the rt125 and he loves it
about $110usd at the time
make sure you tell the parts guy which side of the road your country
drives on so he sends the proper unit
Postby andyw » Sun May 14, 2006 5:26 am
nyarla wrote:Ok so no ideas?
Sorry, no can help.......................but if I'm ever up your way any chance of a ride in that thing :-D
Lights - replace bulbs with better items like Phillips/Bosche/Halford Ultra Bright (same power but about 30% brighter) - adding small rectangular spots like Nobog did (Halfords have cheap, small spots). make sure you install with a relay and independant switch. Will probably being doing this sometime myself :D
2005 R1200GS - 2002 MZ Mastiff: No more :-(
http://www.MotorcycleInfo.co.uk
andyw
Postby Sourcer » Mon May 15, 2006 1:50 pm
I find out that the original headlights to my Mastiff sucks big time. I then decided that I want to replace them with a similar designed lights. The problem is that I have no clue where to find it.
Sourcer
Postby BRAAAP ! » Mon May 15, 2006 2:52 pm
hi,
I fitted the streetfighter style twin headlights to my baggy
similar to Item number: 8065747124 on ebay.co.uk
they arn't the best out there but have lasted for 4yrs so far. . .
two wheels good, four wheels bad. . . .
BRAAAP !
Mastiff head light replacement
Postby Kirk » Tue May 16, 2006 8:43 pm
I replaced my headlights with a aftermarket dual sport unit. Has 55w with good reflector and even had a parking light!
98 mastiff
99 skorpion (wifes)
99 zrx
03 dl1000
09 hawk gt (wifes)
93 F650cs (wifes)
Kirk
sorry double post
Postby Kirk » Tue May 16, 2006 8:44 pm
sorry double post
98 mastiff
99 skorpion (wifes)
99 zrx
03 dl1000
09 hawk gt (wifes)
93 F650cs (wifes)
Kirk
Postby nyarla » Mon May 22, 2006 6:27 pm
Andyw if you ever get to Fife I`ll gladly give you a spin on Purrdy.
Since that post she is a wee bit faster after fitting Dolefins.
Crazy scary in any sort of a chop at that speed though.
Oh you can share petrol costs.
She gets through about 67 litres an hour.
BRAAAP ! How did you fit the streetfighter lights?
Did you just junk the front ironmongerey and fit them to forkbrackets?
Andy
nyarla
Re: Mastiff head light replacement
Postby Sourcer » Mon May 22, 2006 7:55 pm
Kirk wrote:I replaced my headlights with a aftermarket dual sport unit. Has 55w with good reflector and even had a parking light!
I'm interested in your topbox. Where did you find it, and what is the brand and model?
Sourcer
Postby BRAAAP ! » Tue May 23, 2006 10:51 am
I got some 3mm plate, bent it into a C shape to form a bracket to hold the lamps and the bolted the whole lot to the metal work on the front.. .
I'll try and get some pictures to show you inna bit. . .
Cheers,
Ed.
BRAAAP !
Postby BRAAAP ! » Tue May 23, 2006 1:43 pm
Here you go. . .
Please excuse the muck & rust but this is an all year bike
Can anyone suggest a "prettier" way of waterproofing the clocks other than pond liner and tape . . . :lol:
Cheers
Ed.
BRAAAP !
