Chalks wrote:Hi AllI've just stripped my spare Baggy engine and discovered the nut on the ballance shaft was only finger tight with only the lock washer holding it on. No signs of wear or damage though. I've been reading on another forum the shaft can wear when this happens causing a knock when running. My next job is check the nut and use thread locking compound on the motor I'm running.
