by Puffs » Mon Aug 06, 2018 11:08 am
Following a moderator choice that is IMO biased and flawed (someone posting aggressive personal attacks is rewarded, while my technical posts are removed), I have withdrawn from this forum.
Puffs on Mon Apr 03, 2023 4:09 am, edited 2 times in total.
![User avatar](./download/file.php?avatar=11016_1541066059.jpg)
by Blurredman » Tue Aug 07, 2018 5:10 am
Interesting.
And you say you cannot see any alignment marks?
![User avatar](./download/file.php?avatar=9656_1539251465.jpg)
by Puffs » Wed Aug 08, 2018 4:52 am
by AlanJ » Wed Aug 08, 2018 5:18 pm
Hi Puffs, I had a similar problem with my Saxon 301 when a Co powder coated my frnt wheel, they sprayed over the mating surface of the disc. I got it sorted by having the surface skimmed on a drop bed lathe, cost me a tenner. I did think of a solution before the skim but not before the paint people had a bloody go with a file which made it worse. Anyway have a look in the mechanic's posts under Disc Brakes in my name, it's all in there. An idea I thought of to get the paint off the mating surfaces is an electric soldering iron sharpened like a chisel or heat up an old chisel.
Wish you well Alan.
![User avatar](./download/file.php?avatar=10527_1608909442.jpg)
AlanJ
by Puffs » Thu Aug 09, 2018 4:43 am
by AlanJ » Fri Aug 10, 2018 6:04 pm
Hi Puffs, Yes, you are right, it's the deflection of the seals with and without pressure that moves the piston and hence the pads off of the disc. Incidently the frnt wheel still had it's tyre on when I had the disc mounting skimmed. Still on the lathe, after the skim we bolted on the disc and dial checked the runout and it was 0.05. Everything is really great with that brake now. That is on the Saxon 301 but I wish that the frnt hub brake on my TS 250/1 was a lot better, infact it was one of the reasons why I bought the Saxon. Anyway Puffs wish you well with the disc. Alan.
AlanJ
by DAVID THOMPSON » Fri Aug 10, 2018 8:18 pm
do mark the disk and hub on the 4cycle bikes i had this problem on my 2002 rt125
way too much wobble after a disk removal and reinstall
had to try it with a dial Gage several times before it seemed correct
had disk off to change tires and wheel bearings and had a mess getting it sorted
oem wheel bearings were really nasty at 10,000 miles which was part of the problem
DAVE
![User avatar](./download/file.php?avatar=29.jpg)
- Moderator
