[Grand Designs] project - my ETZ 250
Re: [Grand Designs] project - my ETZ 250
Postby Blurredman » Wed Sep 12, 2018 4:39 am
Reminds me of car rear differential gear matching..
1987 MZ ETZ300 - 40,000 miles
Postby parrbd » Wed Sep 12, 2018 5:10 am
Did you try different positions on the splines? IE; when it gets to the tight spot, mark the relative position to the splines then try one of the other positions.
parrbd
Postby Guesi » Thu Sep 13, 2018 11:50 am
Is it a reproduction or an original spare part ?
Some reproductions had the problem that they were not drilled exactly in the middle. So the distance varied and it could not be turned properly...
Guesi Motorradteile
MZ spare parts
Postby Puffs » Fri Sep 14, 2018 3:22 am
Not rotating around the centre - that would explain it. You should be able to measure that.
Postby dirtsurfer » Fri Sep 14, 2018 6:55 pm
Thanks for the input guys. I reasonable sure it was a genuine part , anyway I have now replaced the driving wheel/ clutch centre with a new one, torqued the nut on the big gear down and the gears now rotate in harmony. So I think the issue was old trying to mesh with new. Reminiscent of my first marriage ,my wife was 13 years younger than me , we though that we fitted each other but could not function without clashing. :oops:
MZochist
dirtsurfer
Postby dirtsurfer » Fri Oct 05, 2018 2:58 am
Progress has slowed up a bit as I ride the roller coaster of life.
I have managed to squeeze in a little ETZ time every now and then. I have lapped my old clutch on to the shinny new crankshaft , carefully cleaned off the surfaces and torqued the clutch to 90 Nms , crossed fingers that I dont have the same problem as @skyeport; I hope to get the clutch cover on the engine this week end.
I ordered a replacement stand bumper which I was intrigued to find it made of bakelite. Quaint but not entirely functional in my opinion. Unfortunately it shattered as I tried to install it. So I have opted for a block of seasoned Australian hardwood
The latest issue is fitting the rear wheel. When I finally fitted the cush drive around the right way and fitted the brake hub I find that I there is not enough space to fit the side stand or the spacer that replaces it ( by a good 6mm). The wheel hub is original but I have replaced all the missing parts, brake hube , shoes, cam, cush drive and sprocket hub, axel and sidestand
Remembering that the rear wheel was not in the bike when i got it, I wondered if the ends of the swing arm could have been bent inwards at some stage. I measures 220mm between the swing arms at the chain adjusters.
MZochist
dirtsurfer
Postby Puffs » Fri Oct 05, 2018 5:05 am
I have about 21.5cm between the arms of my 251, with the wheel mounted.
Postby parrbd » Mon Oct 08, 2018 8:47 am
I can't wait to find out the cause of this missing 6mm of clearance. I have never had the sprocket and cush drive off my ETZ250 but no doubt, one day I will need to, so it would be nice to be forewarned.
parrbd
Postby Puffs » Tue Oct 09, 2018 8:32 am
Postby dirtsurfer » Tue Oct 23, 2018 4:54 am
I'm pretty sure its an assembly issue. I put the parts in place without the chain guard and it all seems to fit better. So maybe the speedo drive not meshing properly. Unfortunately I have had no opportunity to do any serious work on the bike since getting back from the desert, really just a few minutes here and there.
MZochist
dirtsurfer
Postby Puffs » Tue Oct 23, 2018 6:02 am
Postby Blurredman » Tue Oct 23, 2018 9:44 am
I don't believe the chainguard in itself, should take any load. It is a plastic (type).
I might perhaps look at the chain guard miniature spindle (?) and also check bearings had been pressed into the hub properly.. I believe there's two in the chain hub.
Postby dirtsurfer » Thu Oct 25, 2018 6:17 am
progress with the engine: fitted piston and cylinder
MZochist
dirtsurfer
Postby Puffs » Fri Oct 26, 2018 4:50 am
Postby dirtsurfer » Fri Oct 26, 2018 9:12 pm
Puffs wrote:I normally try to keep an engine light to ease hanging it into the frame, but heavy works too. And that looks like a Vape rotor.
Out of interest: did you do a re-bore? What piston did you choose?
Currently I'm having mine rebored and I went for a 70.95mm Almot with 0.05 - 0.06mm clearance. Time will tell if that's a good choice.
Yep , Bruce also warned me about keeping it light for remounting. The frame is still tucked away in a hard to get at space in my garage until I can reassemble the rear wheel and move it to a postion where I have room to mount the engine.
I went 69.5 which I think is 1st oversize.
I purchased the power dynamo VAPE as my generator /ignition system was buggered.
Next piece of the puzzle:
All of this was missing when I got the bike
Im guessing that the activator goes together something like this
MZochist
dirtsurfer
Users browsing this forum: Google [Bot] and 61 guests
